but haven't you done just that when you put a spacer plate on the bottom of your engine? It would lower the front driveshafts connection point by the thickness of the plate so therefore alter the angle...yes?
You are right, sump has dropped by 8mm which is the spacer plate thickness. I wanted to further drop my engine as well but rob @ rips advised not to do this, maybe that extra 15mm is enough to make it close to impossible? Not sure myself
  • Replies 277
Posted Images
I suggested that the gearbox had been mounted differently but I was getting at raising the gearbox mounts to tilt the engine forward to clear.. no response :laugh:
raising the gearbox mounts would have the rear of the engine heaps higher than it is now, dont forget the extra height of the rb30 AND the rear of the motor is sitting at around the same height as an rb26. plus the front of the motor is a little bit higher than a stock rb26 and is tilted back slightly.
So you think there was no angular change? more of a uniform lowering?
If I could be bothered doing the maths, I would. But, roughly speaking, somewhere around 10mm raise at the gearbox end would be about 5mm (possibly a gross exageration.. cbf crunching the numbers) at the timing belt cover.
This is stupid, between everybody I'm sure we've though of every possible option! Just tell us already!!
= angular change.
dont forget the engine mounts were modified too.
Edited by SECURITY
This engine was originally built with the intention of replacing the RB20 in my 4 door 32. It soon became apparent that, that wasn't going to happen and a better home for it would be in a GTR, but since i don't own a GTR that would prove difficult, so the RB25 in my Sil80 was the next best thing. BUT that engine is already producing 430rwhp with fantastic torque, and really, how much power can an S13 chassis really put to good use?
So the S13 got the nod and the build started. Went thru 3 RB30 blocks before a suitable one was found. I guess there's nothing overtly special about this build compared to the many others, except it's mine!
RB26 head, light port, decked, CC'd chambers, performance springs, standard valves, stem seals, seat pressures etc etc
Tomei 260, 9.1 cams
Adjustable gears
Custom fuel rail
Head oil return to sump
Siemens 870cc injetors, 2 pintle design
Sard FPR
Cometic HG
GTR pleunum and throttles.
Head Restrictors and enlargend oil returns
Block xrayed, decked and internally painted, welsh plugs etc
Spool rods, ACL pistons 9.0:1 comp ratio
ARP head bolts
ACL bearings
Crank polished and grub screwed
Ross balancer
N1 oil & water pumps
Jun crank collar cryo treated
Enlargened RWD sump with baffles & doors
Now i did have a GT3540 0.82 ex housing but i lent it to a mate to diagnose a problem he was having with his car, which it fixed so i probably won't bet it back :) SO, i can either continue this route, or go twins. I'm leaning towards twins and a set of 2530, be it HKS preferably or -5's
Designed to be a time attack engine so response is paramount. There is only a few with twins that i can find.
Here are some pics, not many but you get the idea
looks like a nice job ahead
f**k sake, whats the go with all the noobs quoting pics and replying twice with absolute crap.
hahaha - go kaiden u funny farker
sorry but i dont know this guy, maybe he can be excused for driving a BRRRRDSHHH (wrx)
he he , its much more interesting sitting back and listening to you guys think about it out load :down:
Between the lot of you, you've got it, just need to work out what "it" was...
Craved, you know me better than that, a side-on shot will give my funny little game away. :cool: Remember, i said i wasn't going to just blurt how its done, that just wouldn't be as much fun as this.!! Besides everyone now knows, if they didn't before, how awesome your coatings are- the candy apple red is just friggin bewdiful!
Fainlly got my Ross balancer- its the stealth black one :D Car is back in the shop with a few little things getting sorted, should be back by mid week if not earlier. Then i can put some km's on it and take it back and lean on it!!
She was a bit doughy off idle but think we've sorted that issue.
Shit myself on Friday- thought it'd had a major failure but turned out that one of the turbo's oil drain had a slight leak and was dripping down straight onto the front pipe flange and soaked into the gasket which caused white smoke to complete fill the shop when started. After a hour or so of thinking, fcuk it's gotta come back out, we found the sneaky culprit- beers all round :D
In the end i put a standard water pump back on it instead of the N1. This is a street car. The clutch Dave from Wrights Clutch Service in Lismore NSW made me feels like something you'd find in a Ford Fiesta, but hangs on harder than Oprah on a baked ham!!
Still to fit the second 044 pump and surge tank, will do that after ive run it in some more. But i did install the Siemans 870 injectors
Air con is now cold again and power steering leak sorted.
Can't wait to get her back and drive it!!
Edited by Simonster
Stop saving the world simon and get back into the cars! ;)
he he, Id LOVE TO. I wish i could, looks like ill miss the the next timeattack round in March. I just haven't had any time to get the RB25 fixed :)
Update with the GTR, the cam timing ended up being the culprit as expected. Changing cam gears. Sorted the inlet timing and she's now got 260hp on 6psi. Fixing the exhaust timing tomorrow, so it's looking promising so far.
Did the exhaust cam timing and she picked up another 20hp. Now 280hp on 6psi @ 5500rpm!! It's certainly looking promising.
Put it in for a roadworthy but needs a few bushes so that should be done by tomorrow.
Just awesome to drive, like a V8, just effortless torque and power on tap. Has a real angry idle now and the exhaust gas is really pulsing now, whereas before it was just constant.
Looking forward to putting some km's on it. Still needs a wheel alignment.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
