  • 2 months later...
you CAN fit te37's with good offset on a gtst, you just have to work the guards a bit.... not a widebody kit, just a roll/flare and its done
easy 18x10 +12 fit... and with te's you really dont need any more dish than that
Any photos of this??? would be interesting to see :) ... also does anyone have some photos of big wheels with flared guards (standard guards)
Since the R33 has a curvy character and i think (purely subjective) that the more squarey shaped wheels e.g. TE37's, LMGT4's, even XD9's don't bring out the best in the car, they suit boxier shapes like R32s and R34s. Rims with sharp ends like Buddy Club P1's, Work Emotion KR Cai's, even BBS styles would better suit the curvy nature of R33s
Hope you don't mind Vu, but i think your R33 converts non-believers haha
Same goes with Silvia S15's
Danny
Edited by squareznboxez
+ another one for P1s....
They rock. Simple and clean shape. They suit the R33 as a 90's era car by respecting it. Too be honest I'm kind of opposed to the whole 'mod movement where guards are rolled/flared etc.....it's brutalising the intended design of the car. In 20 years time the original car as an 'era design' will look x10 better than the highly cosmetically modded stuff of today. They will be like faded tatts or the embarresing haircuts you had years ago.
What size are those P1's BTW? 17"
Edited by Battery_backup
Yeah... the best performance size good old 17 inch =D
Width and offset?
forgot... ill check tomrorw since im taking off my rims to do my rotors and brake pads...
how about advans on a r33? look good dont you think?
P1's do look great on 33's.
Not a huge fan of any 3 spoke wheel, but those look alright I'm guessing because they're black.
I'm not either. They look a bit weak and insubstantial. I wonder if they are more prone to buckling etc?
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
