looks good man,
got close up on your number plate set up looks interesting? u make that bracket?
yeah made it up after being booked by the cops for having my plate on a slant.
Went to court and got off because it actually complied.
Needs to be within 45 degrees on the vertical and horizontal which it was.
Anyway, decided to do the right thing, used rigid brackets behind- bent them to suit the angle then fixed the plate to them.
Had some left over stainless sheet from a range hood, bent it and trimmed it with rubber channel, screwed it over to cover the brackets.
Your favourite wheels being the wheels on your car? So your saying that there is no other wheels you would prefer than yours?
not really...
im pretty basic, i like the shape of mine, i dont really care for fancy wheels, i like basic, race style wheels.
i love the style of tapering out from the center to the outer rim, like mine, i dont know any others in a basic 5 spoke wheel style, that being said i dont really spend a lot of time pondering about wheels :D
everyone's different.
unfortunately we live in a car community that thinks wheels are everything, exhibit A, commodores. im happy with my wheels, and now ill focus on the rest of the car.
