Here's mine.. Super Advans 18's 9.5 +32 Front n Rear. 235's front n 265 rear. The Front left rubs a little after raising it by 25mm.. the right doesn't as it sits a little bit higher, but this only happens if i'm going fast around a corner.. perhaps -2.5 camber will help?
Loving the Advans!
  • 4 weeks later...
Hey mate,
Im loooking at getting pretty much the same set of wheels, they look great!
Just wondering if the 9x18's on the front scrape at full lock? Is it maybe better to get 8.5's.
Lenso D1R 18x9+32 in hyper silver. No rolling or flaring required, but I'm only running 235/40 tyres.
  • 4 weeks later...
These were with my old bridgestones........now have Sumitomo z 111's....inexpensive and excellent performance in my opinion.
WHAT DO YOU GUYS THINK????
Do I need to do anything to improve the look??? or do you think its good?
(I have days when I love them...and days when im not so sure):closedeyes:
If u ever decide to sell your wheels man, please let me know :D
^^^ lower it
I would....but im gettin a new front lip....and sideskirts (which i still need to find to match - any ideas??)
So yeah....I only JUST clear my driveway kerb (by like a cm if that)...n im not running coilovers coz this is my daily ride
But I know it would look awesome lowered.
Ah well
Thanks anyway :thumbsup:
  • 7 months later...
Thank god you got decent off sets on the fronts. Theres a nice silver series 2 GTST here in town that has the good off set on the rear and then shit on the front.
Looks ass but yours having the deent off sets front to rear is a win :thumbsup:
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
