Entry Form - http://www.wrx.com.au/motorsport/WRX_Sando..._Entry_Form.pdf
Supp Regs - http://www.wrx.com.au/motorsport/WRX_Sando...e_Supp_Regs.pdf
Check your entry has been received - Entry List - http://www.wrx.com.au/forum/viewtopic.php?f=23&t=57498
2009 SAU Vic Motorsport Championship proudly sponsored by:-
https://www.sau.com.au/forums/topic/268629-sandown-sun-28-june/
  • Replies 143
Posted Images
just looking at the form, there is a tick box for entry fee and one for driver training.
does that mean if you want driver training it's an extra $145 ontop of the $185? or you have to tick one or the other and if you tick driver training, it's a slightly restricted day?
EDIT: i should read everything first...
"5. Driver Training Group
“Driver Training Group” sessions are a separate group in this event and Drivers participate only in this
group and pay the reduced entry fee.
For this component of the event, the following will apply to all drivers:
• There will be a separate Novice Group briefing and attendance of all drivers participating in this
component is mandatory.
• the club will provide a Driving Advisor / Instructor for each Driver
• Overtaking is not expected or encouraged in the ordinary course of this component of the event. If
overtaking is required it must be done in a safe and cautious manner. Those drivers who overtake in a
dangerous manner will be reported immediately to the Clerk Of Course and subject to penalties (which
can include exclusion from the event). Those drivers who are being overtaken must indicate by
pointing to the side they wish to be overtaken and maintain their line. The responsibility for the
overtaking manoeuvre rests with the overtaking vehicle.
• Drivers who wish the Driver Advisor / Instructor to drive their vehicle in this component do so
entirely at their own risk."
Do we know who the instructors will be?
cheers
Nah, it's the cheaper option of the two.
thanks guys :D i should have read the pdf's more carefully :P
so is it cheaper because you get less track time? i take it you still get to participate in the timed events?
how would this compare to say the Driver Dynamics open pit days? Those days are instruction days as well but they're around $260
well the DD days have some pro drivers giving you indepth instructions.
these will ahve some people who know the track give you some tips..
so really depends on what you looking for
you will learn more from a DD day...but you pay more as well..
but won't get points in the club championship either!
M
M
cool, thanks for that mate
would you say track time is comparable between the DD days and these WRX ones?
Interested, would have been great if they were using an AASA permit, then I wouldn't have to buy a CAMS license :D
Probably time I should buy one....
So 4 * 8min runs even for the driver training group? And after say 3pm to 4pm its a little more open or....? Never been to a club track day.
I've done Sandown once with the driver dynamics group, and Winton during a fun day, but I'm only running some average street tyres and think the driver training might be a good idea...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
