Hey Guys
After following a few of the r34s getting tuned of lately i decided to take the plunge and get my car tuned aswell. So after a few phone calls to CRD i organised the truck and shipped it down to Sydney. The car being a stock standard Vspec11 Nur with a Nismo exhaust i decided to add a few bolt on goodies of them being Sard 700cc inj with a Sard fuel reg, HKS fuel rail, Bosh 044 intank pump ARC airfilter box, Tomei poncams 260's, Apexi power fc and a ATS clutch to handle the increased power. Well what can i say Jim from CRD called to let me know how he went with it and i thought he was having me on exceeded all my expectations shipped the car back home and gave it a test drive and all i have to say is F*** this thing drives so much smother comes on boost earlier than before even off boost it is heaps more responsive than ever before. Oh i would just like to add this was tuned on 98 fuel and the turbos are the standard n1 turbos that come with the Nurs. So on this note i would just like to thank CRD you guys seem to be on a higher level when it comes to tuning and modding GTR's :D
https://www.sau.com.au/forums/topic/268844-gtr-34-vspec11-nur/
Um is the second graph showing PSI?
As in your running 25 pound tapering off to 21 through standard 34 N1 turbos...
Do you have a before graph?
Should be one hellova ride though!
Yes i dont know why the boost tappers off it will hold 22psi it might be the standard wastegates on the turbos or the two cats the exhaust runs but yes it is a fantastic ride.
I expect it declines because N1s stop producing power at the top end over 1.3bar or so,
your car is going to 1.75bar at boost onset, then declining down to the best the N1s can manage.
Is there a boost controller in the mix as well?
Yes there is a HKS boost controller.
where are your torque figures?
On the first dyno pic up the side just under 9000
it feels very torquey when im driving it.
Wow - i thought N1s/-7s/GT-SS were out of puff at about 330kw...
Please put this in the RB26 turbo sticky.
+/- 20kw really, also consider its running a few extra PSI than what most people run (20psi) so all things relative its pretty much spot on :starwars:
ahhh, the beauty of stronger internals in the Nur motor. Congrats Nick.
Stronger internals yes maybe how much stronger!! well that can be argued all day long. Was it the increased strength that gave the power figure above in this instance no i don't believe this was the case either this one was done purely on tuning ability. This thread was not put up to compare anyones car this was put up by me only to share my happiness at my result. There's plenty of other guys on this forum with the same set up running roughly the same amount of power no records broken here just a great setup that has made this car so much more fun to drive. By they way thank you for editing your post if you would like to talk to me about getting more power out of yours pm me id be more than happy to tell you how.
Is there 2 different cars plotted on these graphs?
I see the NUR is making around 320awkws and the R34 GTR is making 358awkws.
So assuming your car is the red line who's is the blue line?
And what happened to the rest of the graph? Speed or RPM would have been nice to see...
i was just about to post that.
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
