Hi Guys,
As stated I need an oil cooler for my R34 GTT.
It's recently modified and running close to max temp. during winter. This being the case I'm going to need an oil cooler before summer.
I don't want to spend a shit load of money if I can avoid it, that being said I'm looking for a reasonably good quality unit.
I don't see the need to purchase an expensive brand. I know there are a lot of cheaper ones out of china these days, but what's the quality like.
Interested in any thoughts people may have.
Thanks
Paul
https://www.sau.com.au/forums/topic/269187-oil-cooler/
On my old R33, I had one from "performance-wise" unsure if he trades anymore, but he had a few threads a couple years back in the traders part of teh forum.
I bought an 11 row cooler with oil filter relocation kit for around 350 delivered, this was a couple years ago now. It worked well and I did around 10 track days last year, no issues at all
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4584159
Hi Guys,
Thanks
Paul
how much were you looking to spend?
there are univeral kits for about 350 - 450$ that have decent quality
Edited by eeiko321
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4584636
Wait on a sec, just to check, your car was running close to max temp yeah........which guage did you get that info from? Also, exactly what temp (in numbers) did it reach?
I have a HKS oil cooler kit, everything fitted up perfectly the first time, i reckon its worth the extra coin personally. Autosport Engineering in Kirrawee fitted it, go down there and tell the tall bloke that mx5 chris and stev0 told you to go there. Probably wont be cheaper but you may score a beer out of him :P
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4586616
Wow, that is a bit warm.
I found a second hand TRUST kit for around the $350 mark. It bolted up first go on my 32, and at the Wakefield track day the temps barely got over 90degrees.
What kind of driving do you do to get around the 100degree mark? Is that just putting around town, or really getting stuck into it?
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4587491
Putting around town it probably runs about 90 - 95 degrees, but when I really put my foot down (for short periods of time) it runs higher.
I never hammer it for to long as I don't want it to overheat.
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4587537
buy a trust kit. sure there are cheap kits at only $350 or $400 but at a workshop they can cost up to $500 to fit as there is a lot of stuffing around to do it properly (route the lines, make a duct etc).
The trust kits come with thermostat which a lot of the cheap kits don't. they come with good cores. they don't come with bonus bits of swarf or dags inside. they also come with lines that are the correct length not crazy long ones that have to be looped around. they also come with adapters to fit the proper filter for the car. they also come with quality re-usable earls fittings, not cheap fittings. plus they seal and never leak. they also come with all the extra little bits needed like mounts, ducting, conduit to protect the braid etc. It's easy to see where the money goes when you compare a $1000 trust kit to a $400 chinese kit.
I know which one I'd buy. and I have used a number of trust kits now on my cars.
one tip is do not get the radiator mounted one. get a kit that mounts the core in either of the side ducts. much better.
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4587611
Yeah I tend to agree with you. I've used all high quality parts in my mods so far (including a trust intercooler) so why start using cheap parts now.
Only thing I don't understand is what's a radiator mounted one (do Trust make them?). How do I ensure I get a kit that mounts the core in either of the side ducts?
Thanks Paul
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4587833
Thanks Paul
the radiator mount ones are ones that mount between the intercooler and the radiator. they mount to the front of the radiator. the problem is with no ducting there and other heat exchangers (intercooler, air con core and radiator) they don't get good airflow and don't work as well as they should. I have used one that way (a trust kit on my old 32 GTR) but it was not as efficient as the exact same core duct mounted in my other 32.
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4589423
FYI I was going to do the same, buy an oil cooler that is...
Ended up buying a upgraded radiator and it dropped the oil temps by about 10 degrees. Also fitted a R33 thermostat to kick in earlier and keep temps lower.
Try that first i think.
https://www.sau.com.au/forums/topic/269187-oil-cooler/#findComment-4592536
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
