  • Replies 46
At the risk of getting shot. *dons flame suit of +5 fire resistance*
I wouldn't consider putting an RB26 into anything other than a GTR or GTS4. Too costly to maintain. Oil problems. Damaged bearings are damn common. On a plus side heaps of aftermarket support.
You want to do an engine swap into something different? Well its going to be hard anyhow if the engine doesn't belong there. Just be done with it and use a 2JZ-GTE or twin turbo/supercharge a 1UZ-FE.
pretty sure it was front
:P
i'm pretty sure i know the car you're talking about... http://www.skylinesaustralia.com/forums/Sl...ay-t191543.html
in which case, it was proven to not be a magna engine bay.
there is NO way a 26 will fit north/south in a magna engine bay as its not very deep, and designed for east/west engines.
there is also NO way a 26 will fit east/west with a gearbox attached to the back of it, my legnum had a V6 which was almost half the size, and the gearbox used to hang under the chassis rail as it was, let alone with a straight 6.
Dont know why, but ive always thought of a VL Calais, Rb26 on a 30 bottom, T51R etc as a thing that would be a fun toy for skidpans and generally driving like a dickhead.
Shame all the douchebags with dose etc have f*ked it up.
And its by FAR the easiest non nissan chassic to do that to for obvious reasons
VL Calais, 26/30, T51R, Transbrake.
i'll take one!
LC or LJ Torana. A nice VK commodore with vl k frame and mounts.
A c110 skyline and a 180b/200b coupe, but theyre Datsuns. Mk3 supra
I remember that rb26 magna, it was converted to rwd if i remember correctly. It had a tranny tunnel cut and welded in, no idea what rear end they used. Was plain white with the standard 14's on it. The owner had too much money.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
