  • Replies 45
I have to agree with everyone here, that is an excellent install!
I have an iPhone too, and I think I will eventually upgrade my Alpine CD/MP3 deck to another Alpine but with A/V and iPhone compatibility.
Here's a quick video of the setup. audio is a bit out of sync don't know WTF happened during encoding:
Looks good D.
That must be a pain opening the glove box each time you want to change channel.
What software do you use to get the movies to your Ipod? I have some that I use now but not sure if it is the best. Movies can some times be a bit grainy.
Cheers
Andy
Looks good D.
Cheers
Andy
Actually I probably won't use the TV a lot so I don't mind it being hidden away. I prefer to listen to music or if needed watch all the stuff I've got for the iphone (even when I watch TV shows they're generally not live and don't have ad's).
I use handbrake, absolutely rules for creating ipod/iphone content DivX and whatever else you need.
I'm thinking that when I start commuting in the stag that I best get an iPod dock installed.
I have the iPod Nano (3rd gen), wonder if you can get docks to suit them?
I like the idea of having it mounted in the front ashtray and hooked up to the stero and tv for h.264 playback.
Anyone know a place in Sydney that could do this fitout?? Crankin' Car Audio??
There are lots of docks available. I found them all while looking for my solution. In the end the boys here ordered a cable form Melb so I didn't need to get one from overseas like I thought. The cable I got will also charge the phone as that was important to me (being a phone and all). I beleive it is universal and will work with all ipods. The cheaper ones don't charge. I went with the cable becuase I got them to build a dock in the ashtray but Andy bought himself a nice dock that doesn't require any fitted attaching to anything (just clips on) - he's using a similar cable to mine.
yep they used a cable from stinger. they are a decent cable to use and quite generic. its when you want control that things change..
bisebee ,
$3-400. depending on the time I spend on it. that said I can probably do it here if I had the entire panel to work with.
  • 3 years later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
