I am in the process of eliminating things and I want to know what is the right gapping I should have on my plugs. I currently bought new Iridiums BKR7E-11s and gapped them down to 0.8mm but I am thinking that I may have damaged the tips when gapping one or two them. I want to know what is needed for my setup as I am going to be getting some coppers and replacing them today. I have a stock Neo RB25DET in an ER34, it has a FMIC, EBC set to 0.5 bar low and 0.9 high boost. I have used high boost once and won't be using that until I do upgrades later on. The car has a Trust Air Filter, Blitz ECU, and pther than that a Trust Oil Cooler; what gapping is recommended as I have a serious hesitation problem that I am trying to resolve?
https://www.sau.com.au/forums/topic/269900-plug-gapping/
yeah i would stick with BCPR7ES and gap them to .8.
95% of r34 break down issues are related to the coil packs because they were very crappy from factory. known issue
+1 been using them gapped to .8 with splitfires for a couple of years now and no issues at all
https://www.sau.com.au/forums/topic/269900-plug-gapping/#findComment-4593787
For Jap plugs eg. Denso, NGK, every 75hp - 100hp upgrade always move to a step colder plugs. Stock plugs, if im not mistaken is a .6mm or a .7mm.
The higher the no# the colder the plug is.
8 --- 0.8mm (.032'')
9 --- 0.9mm (.035'')
10 --- 1.0mm (.040'')
11 --- 1.1mm (.044'')
Go with a 0.8mm to be safe.
Best plug ive used so far is the NGK Iriway 8. Ive moved to 9 after mods.
https://www.sau.com.au/forums/topic/269900-plug-gapping/#findComment-4594237
i believe stock plugs are 1.1.
Also i believe that the more mods you do the smaller the gap should be, hence why most people go from 1.1mm to 0.8mm.
https://www.sau.com.au/forums/topic/269900-plug-gapping/#findComment-4595129
you are confusing gap with heat range. that advice above is wrong.
the number in the plugs for example 'iriway 8' is NOT the plug gap. that is the heat range. they are two different things.
the stock plug gap is not .6mm. they are a heat range 6 plug, with a gap of 1.1mm. yes as you get more power you need colder plugs. that has nothing to do with gap. you want the gap to be as large as possible without misfiring or plug arcing out. usually with more boost and power and colder plugs you need to close the gap down to about .8mm but if you can run more gap by all means do so as it gives a bigger spark.
there is also a suffix with NGK plug numbers. so a BCPR7ES-11 is a 7 heat range plug with a 1.1mm gap. a BCPR7ES with no suffix comes gapped to 0.8mm. a BCPR8ES-11 is an 8 heat range plug that comes gapped of course to 1.1mm and so on.
https://www.sau.com.au/forums/topic/269900-plug-gapping/#findComment-4596005
First things first... Iridi/Plati - waste of money.
Coppers, simple as that.
Second - plug gap depends on the setup. If the ignition system is WORKING WELL, a gap of 1.0 - 1.1 should be used for mild performance mods and boost.
Third - ALWAYS start @ 1.1 Gap and work your way down. Dont just assume 0.8 is 'best'. If your car runs well @ 0.9, use that - simple.
4th - search, there is a whole thread devoted to spark plugs, and its referenced from the FI Quick Ref Guide and fully detailed
https://www.sau.com.au/forums/topic/269900-plug-gapping/#findComment-4596014
Guest
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
