how much do both of these manifolds retail for ?
both are around the $1100 mark for a standard T3 flanged manifold.
an advantage the ETM product has over the 6boost is that they are laser cut to suit both RB25 and RB26 stud pattern. which is handy if you wish to sell the setup later on.
Edited by TiTAN
  • 11 months later...
I can't complain with my ETM set up only issue is it has a major boost spike. Goes from 15 to 24psi. Mine is plumbed off the housing not the manifold and the only thing anyone can tell me is that its where the gate hase been plumbed in
It will be coming off soon to go back and run a conventional off the manifold set up
Its a tial 44mm and it was screamer and we dropped the screamer pipe off the gate completely to see if it was a restriction but it wasn't. Tried a Turbosmart 45mm gate with the same result. had the turbo inspected and all is well. Plumbed in new vac feed with larger vac line and still no boost control
Weapon, even if you change to a conventional style manifold setup you may still suffer from the same issue. Get whoever welded the wastegate outlet on to redo it properly. It looks to be coming off at 90 degrees to direction of flow.
Should be shaped more around towards the rocker cover so the exiting hole nearly lines up with the exhaust flow into the exhaust housing. As much as clearance will allow.
Like this...
Yea i know :P i was getting told that until the guy tuning my car showed me 3 other GTR's in the shop that had just been tuned. 2 with T04z's and a then one with a GT3582 same as mine running 6 boost mani's with the gate off the manifold. All running tial 44's and the boost line on those were almost flat
  • Like 1
funny enough this is only going off my setup
i run a 50mm external gate setup from my gt3582r
i use to run a vacum line from the copy greddy inlet manifold, i then decided i wanted to shorten that vacum line and pickup vacum from the cooler pipe that comes off my comp housing so i got a nipple welded on, hooked up vacum so the line was now bout 25cms long instead of a mtr.. what do u know all i got was big boost creep upwards to 1.6-7bar.. put it back to inlet manifold vacum and havent had a problem since.. could be worth trying neway..
Ive got the same manifold with a 3582, with the gate off the collector but using a 48mm progate, no issues here. Plumbed back in next to the gearbox too.
Its getting boost pressure from the pipework just after the compressor.
  • 7 months later...
  • 1 year later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
