  • Replies 69
For those who can read Japanese, can you please translate the first option?
I know that the second option is the pop-up screen.
I assume that it is leather, but can someone please confirm this?
Edited by iamhe77
This is the main screen, not sure how to bring up the list of factory fitted options tho ;)
Any one shed some light?
I've just got FAST 2009 JDM up and running if anyone wants a DVD copy :D
Hey Bis-e Bee,
I like the aero kit on your stagea. It looks fast.
Speaking of which, where did you get your copy of Fast 2009? I would love a copy. I have one that i downloaded and it is giving me all sorts of trouble.
Cheers,
Hey Bis-e Bee,
Cheers,
Thanks for the nice comment on my aero kit ;)
I painstakingly downloaded Fast 2009 from a Russian site, 48 files of 100mb each from RapidShare (15 minute wait between each transfer).
If you are going to the meet in 2 weeks, I will have a stash of copies for those interested.
Ouch, thats a bit keen for me.
Where is the meet. I may have to check it out and meet some of my fellow stagarians.
+1 for a copy
http://www.skylinesaustralia.com/forums/Ns...rs-t266253.html
Make sure to lodge your interest if you are going to attend so that you can be added to the list!
STTMQ is 'leather subrare combi seat' ( black )
You FAST is displaying Chinese characters, unreadable, change the font to something like "Kozuka Mincho" for japanese.
My apologies, I had NJStar set to Chinese :)
Is this better?
This is the main screen, not sure how to bring up the list of factory fitted options tho :D
I've just got FAST 2009 JDM up and running if anyone wants a DVD copy :P
i would love a copy, Stephen.Just let me know how much to get one to me in Caloundra,regards graham :dry:
i would love a copy, Stephen.Just let me know how much to get one to me in Caloundra,regards graham :D
Send me a PM so I don't forget!
I'll get around to it in the next few weeks, should only cost a few bucks to post, will advise.
  • 3 weeks later...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
