RB26DETT
Ported and Polished Head
HKS 2530 turbos
Forged and balanced internals
Aiming for 350awkw
Couple questions guys;
1) Getting ready to reassembly the motor and I need to source a new set of gaskets for car. Should I use metal gaskets for the intake manifold/throttle bodies or is this overkill under 20psi?
2) When picking a head gasket I dont want to loose anymore mid range or bottom end but with the goal of 350-400kw should I buy a 1.2mm head gasket to keep things a bit safer, or stick with the 1.0mm?
3) Putting a power FC back on her, should I do the first engine start off the stock ECU from before rebuild then once it ticks over switch to FC?
4) How many KMs should I have on the clock before the first tune, a lack of good tune and the RB oil problem was what killed the girl first time round, turns out stock ECU on bigger turbos is stupid
Thanks guys
Genuine nissan gasket kit + jap brand headgasket kit which includes the intake and exhaust metal gaskets (tomei or Hks)
my mech recommends a 1.2mm gasket
if the last tune was bad you'd want to retune it for run in before a power tune
When mine was rebuild (and the previous motor)
PowerFC in from the start, bed the rings, tune it up... drive it home.
Nothing more too it. Oil change 1,000-2,000km's later just for a look-see and then 5,000km as normal.
Running in is a myth - i've seen more RB's belted from the ring bed in than i have RB's that do the '1,000km' run in rubbish. None of them run any different so why bugger around for 1,000kms? ;)
Running in is a myth - i've seen more RB's belted from the ring bed in than i have RB's that do the '1,000km' run in rubbish. None of them run any different so why bugger around for 1,000kms? :cheers:
Agreed.
As for gaskets i alwasy use a phenolic gasket on the inlet (big drops in IAT on a GTR and RB30's) but for the headgasket i like to know what material has been removed from the head and block during machining.
A metal MLS head gasket and a genuine full gasket kit can now be supplied in a kit (minus gen head gasket) from MDS spares in melbourne at alot less coin than everywhere else.
Agreed.
got a number i can yell for a price?
  • 3 weeks later...
Nobody here can tell you what head gasket to use...it depends if the block has been decked and how much, head been has been ground and how much, what sort of pistons etc etc...everything to do with the coompression ratio. The person who is building the engine will be able to tell you...you could use a standard Nissan gasket if you wanted to be really safe.
Id go the gasket set from MD Spares. It is actually a genuine Nissan kit but without any Nissan markings on it and therefore much less $$.
Use everything except the inlet gaskets.
In their place just use Threebond, as the paper gaskets will blow out under high boost. Just make sure all surfaces are clean, do not machine any surfaces as it will create big dramas, just clean very carefully with a scraper.
MD Spares kit is cheap, I think justjap sell them a few $$$ cheaper.
A friend is assembling the engine, standard compression pistons, the block was cleaned up but I dont remember being told a heap was shaved off it, I want to run around 400kw when finished with this motor so I think I will get the metal head gasket to allow safety margins.
CRD sells a Nitto rb26dett metal gasket set (Intake manifold, exhaust manifold and throttle body) for $215 delivered to me, alot cheaper than the jap a/m option
yeah the greddy ones from greddy oceania are cheap atm too, they are on the clearance list... bugger maybe it was link and Nismo items...
Edited by URAS
  • 2 months later...
With the nitto or other metal type intake manifold and throttle body gasket, are you meant to use any type of gasket cement (permatex #3, etc.) when you go to reassemble the bits?
Taking the opportunity to install a oil filter relocation kit at the same time to get rid of that headf$%k..
f**k I hate the mess taking a stock filter off in a GTR makes, im probably a tardo which is why its messy, the relocation kit is the way to go...
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
