Item 1:
RB26dett cyl head of an R32 complete. Previous owner hat it rebuilt but never used it, I got it for a 30/26 build but am going a different way. Has obviously never been used, has only been sat on a bottom end to 'look at', never been bolted to a head since rebuild. Includes Customised polished Rb26 cam covers with welded in speed flow fittings and 90deg bends, polished cam gear cover and valley cover, inlet manifold with polished throttle bodies, polished throttle linkages (which need assembly), inlet plenum (still in black paint), all manifold parts like the air channels etc, CAS mount and CAS, temp sensors and air regulation valves ETC, stock cam gears and what ever else I have for it.
$1800 with everything or $1600 with no cam covers, rocker covers, valley cover or cam gear backing plate.
Item 2:
Power FC for R32/33 GTR. Brand new in box, never used. Has all manuals and serial numbers ETC. In perfect condition.
Has hand controller......Not sure what else to say about it!
$1200
Item 3:
New never used JUN crank collar, has grub screws and instructions (in Japanese but the pics make sence).
$100
Item 4:
Brand new never used Trust twin turbo high mount Exhaust manifold. Has T2 turbo flanges and trust triangle waste gate mount.
$1000
All in Melbourne, will put up pics tonight.
My number is 0418 574 513.
SMS me only BEFORE 9PM! Dont call as I cant answer the phone while working.
To all the PM's (I can only reply to one PM every 5 mins!) I will not sell the RB26 covers on their own, they either sell with the head or I will keep them for the new project.
More gear, this time RB30 stuff.
Item 4:
Polished RB30 rocker cover. Could use a hand polish to bring it up to its best again. Includes larger breather fittings. DOES NOT INCLUDE NISMO OIL CAP!
$80
ITEM 5:
RB30 Cylinder head, good condition, includes WADE 1528 camshaft, machined lifter bodies and recently replaced (6 months) lifters. Have spec sheet for cam. Gave a slightly lumpy idle.
$250 the lot
**WILL NOT SEPERATE, WILL NOT POST**
ITEM 6:
T03 (VL) Turbo and Manifold, complete with oil and water lines. In excellent condition, the usual minor side to side shaft play, no thrust play. Works great, does not leak or smoke. Pics taken as soon as it was removed from the engine, will be cleaned up a little. Manifold has no cracks or leaks, will need a new turbo to manifold gasket tho.
$500
ITEM 7:
Custom inlet manifold. Bolts to N/A runners. Polished Alloy (needs a repolish though), Internal Bell mouths, polished XF throttle body, has provision for idle speed controller under plenum. Works great, awesome throttle responce compared to long cooler pipes.
$500
All in Melbourne.
** PRICES DROP**
RB26 HEAD. $1600 complete, $1400 without polished covers.
POWER FC $1000 FIRM.
Twin Turbo Manifold $800.
Someone buy this stuff :bunny: The 3L gear ran really well in my car and we only upgraded after i blew a head gasket.. Its all in great condition..
mr collins is up in sydney tonight and he wishes me to telll you
ya muma is a arse hat
Happy birthday man.
See ya at the island. Bring ya 31 woman.
Now buy my stuff!
hi, just wondering what flange is the twin turbo manifold setup (T2? )
Just wondering how big of a turbo I can run off each. Also was there additional bracing to the engine block?
cheers
Andrew
The flange size is T2. A pair of SR20 turbos fit really well, or something along those lines.
There was no extra bracing to the block.
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
