Nice results...but
I cant help myself. CRD gave the GTR its cult status in Australia? :) LOL i am not sure, but based on the amount of Suzuki GTIs you used to do back in the day i will pay the fact that you made those the cult car of the early 90s :P:D
Again, good work on the results! :P
Its easy roy.....Let me give you some instruction to be able to see it there way........insert your head as far up as your own arse as possible......
  • Replies 96
Posted Images
Nice work!
What sort of boost is it running? Excuse my ignorance but was it a turbo upgrade or is still running the stock ones?
17 pounds I think. Stock turbo. Its the investment in the HKS kit up front that makes making power in this car easy. Jim did the cam timing today which yielded another 20 or so kilowatts atw. Still waiting for injectors and spark plugs to arrive. Once I have these goodies, and another round of tuning, should be ready for another night at the drags. The thing runs 0 -100 in 3.1 seconds consistently now. If I nail a launch I could see sub 3.0, in fact I may well have done that on the way to the 10.8 run the other night. Anyway, if I can fluke a cold night, some high octane fuel, and a good launch a sub 10.5 should be do-able.
  • 10 months later...
Ok, I'll come clean, CRD are now completing phase two of my build. I previously did the HKS 570 kit, injectors, cobb etc. As you can see below we are now doing the serious stuff. GReddy turbo kit, HKS intercoolers, HKS tranny cooler, Willal sump, fuel pump (E85), 1000cc injectors, 4 inch exhaust.
Should be done in a couple of weeks...
Jim has built a custom 4 inch exhaust (3.5 inch dump pipes), single side exit. White 35 had it fitted yesterday - much quieter and no drone for normal driving, unreal on boost.
post-61024-1280544382_thumb.jpgpost-61024-1280544386_thumb.jpgpost-61024-1280544393_thumb.jpgpost-61024-1280544399_thumb.jpg
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
