Might be worth investigating what another one is worth, if they are cheap then add in the power and see how it goes. If they are a fortune a cooler might be a good option, also have a chat with some of the 4wd shops for what they are doing with them.
Blokes on a Challenger forum have driven their bone stock autos loaded up and towing caravans around Australia with no problems so I reckon mine should be OK on tarmac roads towing 2000kg all up max. But an auto trans temp gauge might be good, will check that out. Don't want to add stuff that is apparently not necessary, spare $ go to racecar :)
So cbf reading bucket load of pages!
X trails....say 09 on wards diesel.
I've noticed that the autos are 1350kg towing and manuals are 2000kg towing. What's reason behind that? And I guess towing the mx5 and trailer, would it be that hard on the manual?
Seen a few around 20k to 22k which don't seem too bad.
Reduced towing for the auto usually is because the auto is the transmission weak link. Torque is what matters with a diesel, I'd say 300nm minimum for your application.
Xtrails won't be happy towing - they'r all kinds of shyte.
If it's a very light car on a very light trailer (say total 1300-1400kg) you might get away with it. If you're considerint towing up to 2 tonne then forget it. Xtrails only just make the cut as a family car. They're not designed to tow.
Chris,
This might help you, is the petrol versions I think so deisel would be better
http://caravanersforum.com/viewtopic.php?f=2&t=4842
New Jeep Cherokee on special offer, $30k for the four speed auto V6 petrol (diesel with five speed auto is an option) drive away, 2270kg towing capacity. http://www.jeep.com....cherokee-towing
Edited by 260DET
$30 k is cheap for a base model which (I think) is being run out. It's a nice car and would do the job if you're towing something light like an mx5 and light weight trailer.
For example, my Jeep Grand is rated to tow 3.5 tonne, but I personally can't imagine towing that kind of load. I tow a 33 gtst with a 750kg trailer and various bits and pieces. I reckon around 2.5 ish tonne is my personal limit, giving a bit of overhead or buffer.
Pretty sure it was suggested there may be some other options some pages back?
Again - the Cherokee still very cheap! Wonder if you can get stock?
personally i wouldnt touch a jeep, the missus wants a wrangler and i am spewing, terrible fuel economy, parts are expensive and depreciation is one of the worst on the market.
it depends though, if you only drive her once or twice a month and you dont care about fuel consumption get a 100s v8 land cruiser
$20k should get you a nice one
my cousin has been towing his 1800kg boat in his ls1 wh statesman for years and it purrs along the freeway
$5-10,000
07 v6 hilux dual cab sr
15-20.000
id take a hilux anyday of the week over a navara, triton, colorado or mazda for that matter
even a v6 territory you can have for around the 10-13k mark for a decent one
but def no jeep
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
