I feel weird saying I have a bit of badge snobbery by leaning toward the Hyundai :P
Toyota FJ is basically a Prado underneath I understand, so should serve you well.
They're but in the USA? Does that explain why no oil burner donk?
hello friends,
am looking at buying a diesel tow car/4wd with a budget of 10 -> 15k. it would be towing my S14 on a car trailer.
i was leaning towards a 80's series landcruisers post 96 were the tow rating was changed - what are opinions on these?
can anyone please suggest some other options that would suit my price range?
cheers
hello friends,
cheers
Are you needing anything else from the vehicle other than towing ability?
Seating capacity, daily driver, economy requirements........ ?
not so much, mainly just towing and off road ability for some fun
half decent fuel economy would be nice but i have a daily also so not essential.
cheers
Well as soon as you say "off road ability" which I reas as "serious off-road ability" I instantly think live front axles.
So, 'Cruisers and Patrols are on the menu, wagons or utes depending on what suits. Avoid British shit but we all know that.
Don't get carried away with lifts etc, coz the higher you go and the bigger the tyres, the worse they tow.
Diesel Cruiser or Patrol, aftermarket turbo kit if it doesn't already have boost. Budget i9s the hard part.
Personally, I'd be having a crack at busting this bloke's chops, or trying to find a GU Patrol ute with 4.2 turbo.
http://www.carsales.com.au/private/details/toyota-landcruiser-1994-14020428?base=1216&vertical=Car&cr=10&eapi=2&__N=1216%201246%201252%201247%201282%204294962861%204294962570%204294680273&num=15&silo=Stock&Range=Price%3a10000%2c20000%7e0.5&sort=default
yeah 'serious off road'
wow at that link. 20k seems pretty crazy. newer versions are much cheaper here in perth >.<
not sure it would be up for the towing capacity either
pretty much what i thought - will target the cruisers and pooohtrols
cheers mang
cheers mang
New ones attract less money because they have the shitbox ZD30 in them and will blow up. If you read back I rave about my 4.5l dual fuel Pootrol quite a bit, but think it is justified, I get 18/100 driving daily, heaps cheaper to buy and run day to day than a diesel, and debatable how much more it costs towing.. The 4.8l is a heaps better motor again
8.4L/100 is good for a truck, how does it drive.
Now have a trailer for the Challenger, PI over easter is the plan. It's going well, only thing is the suspension needs tuning for Aussie roads. Thinking about getting a set of Bilsteins to improve it.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
