Any of you guys had any issues with your wipers?
There seems to be a little slop in the mechanism that when running on intermediate the wipers stutter on return. Not sure if its just the cheap blades or if its wear in the motor assembly its giving me the shi#s.
https://www.sau.com.au/forums/topic/272328-m35-wipers/
No trouble at all, infact the smoothest operation i've ever had. I know what you mean, the wipers on my truck are doing that when there's not much water on window, really annoying! I'd splash out on some new blades.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4627402
Just put a new blade on, I replaced it the first day I got my car...
As I was going
BOSCH Areo Twin blade is the best I have ever used...
450mm and 530mm is what you need for a perfect fit for our car...
i bough them for around $ 25 each at supercheap auto!
cheers.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4629317
  • 1 month later...
know what you are saying exactly -- annoying stutter! mainly on intermittent ... dont think its the blades .... any luck finding out why?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4702467
I haven done any more research into my problem. I just dont use the intermitant. Its very weard as some times I think thyat it is the way it is controlled. Now and then I will get a quick 2 wipes in the int function.
I was going to pull them apart and see if I could reduce the slop.
By the time I get around to it I wont them anyway
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4702970
Mine had this problem when I bought it, I pulled the mechanism out and found the plastic ball cup was worn/broken. I replaced them with rose joints, then they worked smooth.
I have one spare plastic cup now.
The assy isnt hard to get out to check.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4703303
The problem with me is that I dont have time to be messing around with it.
I will try to get onto it this weekend.
Whats a rose joint?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4703355
  • 4 years later...
Thread dig, but very relevant.
I have a similar problem, and possibly the same cause.
When the wiper changes direction at the bottom of it's travel there is a clunk. Shifting the wiper myself lets me move it about 100mm at the tip. I expect there is a linkage or the above mentioned bush flogged out somewhere giving the joint play.
Any guides or information on removing the assembly from under the plastic cover?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7271791
Guys, this is a common problem for 2001-2003 stageas and skylines. you don't have so much dirt on the roads - so your wipers don't used to be as tired, as ours, and it is not common on your sterile roads)
you have to clean power distributor on the wiper's motor to remove gray dirt from the separating point oin the line, supporting the periodic duty!
just look for some pics
this is pic of my first Stagea. don't look at dirt - a wash engine room once in 3 month, but it has no affect...
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7273282
That's not the issue with his though, the white bushes on the arms flog out on some cars allowing the blades to flop around like a slapper's arse. ;)
Never seen those contacts being a problem on the 80 or so V35's/Stagea's I have worked on, can't be a very common issue... Perhaps it's the snow buildup on the blades in winter over there causing excess current draw?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7273325
Scott, difficulties in translation) i missed with a problem)
the problem i wrote is only for 2001-2003 cars with mileage over 200 kkm - probably, you are right, hard work with snow matters
white bushes are too easy to find as a reason, for our severe circumstances)) - in Russia original spare arm with two bushes is around 10USD, replace and forget
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7276267
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
