I have been wanting to get a nice 2nd car for a while now and really want to get a skyline, Im preferably after a manual r32 gtst or gts. What I would like to know is how much I will need to buy a fairly cheap stockish example in average/reasonable condition?
Right now I can pay up to 6k for one, not including 1.5k set aside for maintanance and repairs. Is this reasonable? I'll probably do around 5-10k kms on it a year so what can I expect maintenance costs to be?
https://www.sau.com.au/forums/topic/272447-can-i-afford-a-skyline/
  • Replies 42
@ $6000 NO
I would set aside 8-12K for a R32 skyline. Some that you pick up for 8K will be that cheap for a reason. Loads of km's, bad panels and paint or absolutely thrashed motor etc. If you buy one for a lil higher it a neat clean car.
Then comes insurance of 1-1.8K for full comp if you go that way. And with the cheaper car something will need to be replaced soon enough cos its so cheap.
Don't bother getting a GTS, it is non turbo and too much of a mess around to turbo (via engine swap or bolt ons)
If it near 100,000km you will need to change the timing belt, maybe water pump etc. which can cost up to 1000$
If you don't have 10K get a S13 Silvia or a 180sx. They are cheaper and more common. But if u can hold out and save up get a R32 GTST, they are brilliant cars
/my 2c
stealthed: u can also get an R33 for 9k would u buy a manual turbo R33 for 9k? id rather pay 12k for an R32 and buy something good
Yea, I didnt say "Good" 32, But thats Generally where they start for Prices. +1 to Buying a Decent one for around 12k tho
I sold my R32 GTS4T auto for just a touch more than your budget, was mechanically superb, just needed some of cosmetic work. Shop around and you'll find one.
Obviously the mint ones at 11-12k are the best but if you can't afford one, you cant afford one lol.
OVA 9000
LMFAO!!!!!!!!!!
to much 4chan?
I agree that if you want an import on a budget then s13/180sx is the way to go for your budget
otherwise you will need to save more for a Skyline wheter it be a 32/33
why is everyone going on about insurance?
By the looks of it he wouldnt be even be able to afford the excess that would come with full comp for a turbo import. It would prob be close to 2k. So why bother? Just be wasting 1.8k minus say 500 for third party = 1.3k.
Just go third party + fire and theft and leave it @ that.
Use the 1.3k on something else. =)
If I cant get one for 6k then I'm just gonna save up a bit more, currently I'm saving $100-150 a week so sooner or later I'll have enough. I'm more interested in how much I should have set aside for maintainence and repairs. What does the average stockish 32 gtst cost to maintain per year, is 1.5k enough or will I need more?
As for insurance I'm an 18 year old male no crash history but a 71 in a 50 zone speeding ticket so I'm not even going to ask about full comp in a turbo import, I'll stick with 3rd party maybe fire + theft. How much is this gonna cost roughly?
My old bare 3rd party was just over $300 (no fire & theft though) with Just Car, I was on Ps, was 21 & have no fines.
JC also quoted $550ish for fire & theft so I would say it would be around $300 to $400 for you depending on where you live & stuff.
iv seen some 32's go for 6K, i purchased my last R32 GTST Auto for 6500 from NSW but by the time i freighted it, cleaned it up alot, converted it to manual, put rego on it, it owed me about 9K.....if you purchase one ex east you will pick one up cheap.. auto's are allways cheaper, manuals you pay a bit more for usually. most 32's under 8K are usualyl pretty rough tho..
if your buying a 32 under 10K be prepared to throw some dollars at it for maintanence
Edited by BANGN
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
