Quick question guys......
Is it normal for rb26 to be so rich on idle?
It sits anywhere from 11.6 to 12.5 on idle once the engine is up to temp.
Thought it was a little strange so i checked it out on another 26 what do ya know.... same thing!
These two 26 however are not in its "original" gtr chassis, so i just wanted to confirm if a original gtr behaves the same,or if there might be a problem with the wiring when it was transplanted.
Both are R33 engines running stock ECUs, 3" exhaust, 12-14psi, one with walbro pump,one with bosch, intake pods and using 95 fuel.
The car pulls very good ,no misfiring or hesitating, although i find the idle is a little lumpy and it uses a lot of fuel and my rear gets a little black soot after a while.
Is this normal?
https://www.sau.com.au/forums/topic/272627-rb26-afr/
OK some more info.....
Hooked up a pfc out of the box (UNTUNED) and got the following
With the ign on O2 (1) 0.04v
With the ign on O2 (2) 4.56v
On idle O2 (1) fluctuating between 0.04v - 0.88v
On idle O2 (2) constant at 0.12v
AFR at 12.5
At 1600 rpm O2 (1) constant at 0.92v
At 1600 rpm O2 (2) constant at 0.14v
AFR at 10.8 and couldn't rev any higher because it was starting to break up.
Also tested and got a 12v for the heater supply at the two sensors.
So i guess O2 (2) is screwed?!?
And why O2 (1) is only cycling at idle, and not when revved to 1600rpm
What do u guys think?
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4633361
Not sure what u mean???
you can switch off the 02 feedback to the ECU.
go into etc and function select and change the 02 option. if you are unsure look at the power fc faq.
or you can call me on skype or something and i can explain
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4633511
I installed my new wideband setup in my R34 and ran it around for a few weeks with the car 100% standard so I could get a picture in my head of how they japs tune them from factory.
Idle is 14.6-15.1:1 when warming up and when up to temperature. Idle stability when cold is achieved by idling faster, not richer.
It ran 13:1ish on mild boost too up to about 0.4 bar or so, and only got to 12:1 at full boost (0.8 bar). It dipped into the mid 11's toward the top end of the rev range at full load as well.
I have an FC in the car now. The load points around idle are at about 0.985 or something... That produces a 14.6:1 idle AFR. Check your temp corrections if this is way out, and as suggested turn off O2 feedback. It probably wont make any diference, but who knows the fuzzy programing logic that goes on inside these ecu's...
With my previous gtr and the tune I ran in it, I only ever turn that on after the car is tuned. And even then it was probably correcting very little. It only really comes into play when driving up hills to improve my fuel economy as at light load level ground cruising i'd run 16:1 @ 60km/h and 15.5:1 up to 100km/h. Above that its 14.7 at any sustained level ground speed.
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4634379
Ok i understand now.
But what difference should it make to tell me if the sensor is bad, being that the pfc is running on its base map?
Turning them both off will stop them referring to the O2 - what good is it having them looking to a dead O2 for a reading? Its no good.
Hence turn them off and watch what happens :laugh:
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4634515
Hence turn them off and watch what happens ;)
well i hooked up the pfc again today switched off the feedback control and nothing happened!
Afr remained the same and the O2 voltage (1&2) remained the same.
Also with it on or off O2(1) kept constant at 0.84v where as yesterday it was cycling between 0.04-0.88v
I pulled out the vac line for the brake booster thus creating an air leak so the wide band went lean and while peddling the throttle it was cycling the afr from rich to lean and the voltage on the O2(1) sensor bounced between 0.0-0.98v which seems up to scratch.
O2(2) however remained at 0.0-0.2v
I know there must be a few stock gtrs well with pfc installed.
Could some one just run outside, and check their hand controller and tell me what the voltage reads for the O2 sensors when the car is now started and after warming up. :D
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4635872
With closed loop off the idle afr regardless of what it is should be stable. Lets assume you have a 14.7:1 afr at idle, that should be 0.5v on the narrow band. The factory sensors have a very narrow operating band where 0.45-0.65 is the only usable voltage range where the afr can be read accurately. The limits of the sensors range is 0v = lean and 1v = rich.
Yesterday when you saw it cycling it was the computer operating in closed loop mode trying to hunt around the 14.7:1 afr of 0.5v. It will stay on the rich side of things with the o2 feedback turned off.
https://www.sau.com.au/forums/topic/272627-rb26-afr/#findComment-4636643
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
