its not exactly the easiest conversion but its doable.... ive already gone through all this b4.... all gtr components bolt straight up etc.... the annoying part is making the attessa work.... if u can get all lines reservoir computer wiring etc u can make it work.... the only problem aswell is the transfer case fouls the tunnel due to it being rwd factory floor pan but thats easy sorted and if u wanna keep ur rb25 im not 100% sure if the stagea sump will suite i dont see y not but i guess get a stagea awd sump from the 25 version check diff ratios etc... that side im not sure.... its alot of work and alot of money... make u think y bother and just buy a gtr least u get the pumped guards looks aswell..... but yeh gr8 idea still. let me know how it goes
Short answer as it has been covered many times.
You can do it, but there are a lot of things you need to get hold of and it will be costly. If you were given for free what you need it would be worth doing just for the fun factor of the build.
You'd be better off buying a GT-R or Gts-4 if you want AWD.
Use the search function and you'll find what you're looking for.
Cheers for the summing it up for me guys.
"the only problem aswell is the transfer case fouls the tunnel due to it being rwd factory floor pan but thats easy sorted"
Exactly what I didn't want to know. How is this overcome? Expensive?
Thanks again
a stagea 4wd sump wont work because they are just a normal gtr sump, u really need either a stagea rb25 engine thats already 4wd (they have the bolt pattern on the block to suit the 4wd and 2wd sumps and the normal 2wd rb25s only have the 2wd sump bolt pattern), or u can buy a rb30 sump adaptor i suppose and use that.
The amount of money you'd spend would be more if you were to source everything you need, than if you sold your RWD and purchased a Gts-4.
The other factor is that finding everything you need. You'd have more luck finding an honest cop than finding all of your parts.
The engine/sump/diff combo, the ECU, engine/dash/rear wiring harnesses, rear reservoir, rear diff, accelerometer, etc....
Good luck finding it all.
Really man, just sell your current beast if you really, really want one.
That's the best advice I can give.
Thanks again
I assume you are wanting to use GTR ATTESSA?
In that case its MUCH more complex than just chopping up your floor plan.
You have to get the ATTESSA working via G Sensors and all the rest of it electrically, its not just a mechanical conversion.
If you want to keep the RB25 - buy a GTR and put the RB25 in there. Easiest and cheapest way...
Although why you would do that is beyond me. Same as everyone else that dreams about doing it - and i say dream because reality is its pointless - ends up doing the costing and just gives up.
  • 8 years later...
Waking up an old thread here rather than start yet another new one on the same subject.
Let me start by stating this... in my country we are not allowed to import any vehicle over 2 years old.
car PARTS can be imported for old vehicles but the body can  not be imported.
There are no R33 GTRs here. There is however a GTS-T which is up for sale.
I'm looking at buying this R33 GTS-T if it is possible to fully convert it to GTR spec.
the question is this... if I buy the GTS-T, then buy a GTR in Japan and get it stripped and all the parts other than the body sent over here, will everything bolt on to the GTS-T body ? (Yes I know the rear quarter panels need to be cut out and swapped)
someone on another forum mentioned that the GTR chassis legs curved upwards allowing for the front drive shafts. Implying that the GTS-T chassis legs are different.
What is the true fact here ?
can the swap I'm suggesting be done ?
doingvthe huge amount of work involved is not an issue as I have a fully equipped workshop and skilled mechanics.
wecare currently doing a Stagea  conversion in the same manner. Converting a the body of a base non turbo RWD 25G model to 25T RS-V from Japan.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
