Forget Nistune and go the power FC??? how bout save even more money and get nistune. It can do everything the pfc can do + it actually uses the knock sensor. Pretty crap advise I think. I actually sold my PFC to put nistune in. Also if your tuning it your self the nistune software is alot better that the pfc software
Well thats my opinion, if you think its crap, f**k off. Who are you to say my advice is crap? Everyone is entitled to have their own opinion, and at the end of the day its this guys decision.
The PowerFC can have cold start set-up as good as factory.
Why would you need self-diagnostic mode if the PowerFC highlights voltage parameters that are out of range in the Sensor Check through the Hand Controller?
If its tuned properly, you shouldnt need auto timing retard if you are consistent in using good quality petrol. Admittedly its a good feature to have but not a must. There are more people using Nistune than PowerFC so that says something. Not saying Nistune is no-good but the PowerFC must be decent.
I have no knock sensors. 2 years, 12,000kms so far and 360kw, racing and 8,500rpm gear changes and everything is perfect. Why have the computer compensate for poor tuning, reducing power?
The Hand Controller is also handy to watch things like water temp, intake temp, knock readings and anything else if you like.
Second hand ECU yes, just make sure it works.
GKTECH arent the brand of cam gears, they are the sellers. Ive used them myself and are good quality.
Yes second hand factory dumps.
Get your turbos from Croydon Racing Developments, or horsepower in a box. Theyre most competitive, give CRD a call, theyre great to deal with, they managed to source my turbos when the turbo drought was on. What you want are the 2560-7 or 2860-7. Theyre the same, 2860s are just the new models as far as I know. If you want to make 350-380kw get the 2860-5 model, but that will stress the engine more. If youre going to track it and drag it then id cap it at 300.
You could be lucky and find a second hand set of drop-in injectors $700-800. If not around $1-1100 new.
  • Replies 42
Nis tune hey? Sounds like the go. Will Hyperdrive Motor Sports in the Perth no how?
Ring them and ask.
The cat is real just modified flanges.
Cool :P
So onto turbos. i have been looking at some and the names are all over the shop. Could some one point me in the right direction?
Should be straightforward. I can't add anything over what i've already said, other than that JustJap price for the HKS GT-SS seems very expensive. Nengun used to be $3500 landed including tax.
  • 2 months later...
Ring them and ask.
Cool :(
Ok guys - I have got the turbos in my hot little hands :)
Now onto the rest of the gear
  • Sard 6 x 800cc Injectors R32,33,34 GTR RB26DETT, $789 Delivered (twin spary ) or $689 for single spray.
  • Genuine Nissan Engine Gasket Kit - Nissan Skyline BCNR33 - $350.00 JustJap
  • Ross Tuffbond Metal Jacket Harmonic Balancer - Nissan Skyline BNR32 $675 JustJap (need this as i damaged the current one)
  • JJR Silicone Engine Hose Set - Nissan Skyline GTR (Blue) $299.00 JustJap
  • JJR Intercooler Hard Pipe Kit - Nissan Skyline BNR32 $399.00 JustJap
  • NISTUNE from Hyperdrive (Andrew is awesome guy! Helps me heaps) about $860 with tune but i'm bugdeting $1000 incase something pops up
  • Briaded oil and water lines Ebay for about $300 (waiting for another guy to replay as to what grade/crapness they are)
  • Motul 500V oil
  • Green coolant stuff (can't remember the name)
  • Front Diff (BROUGHT)
  • GT2680 - 5 turbos (BROUGHT)
  • JJR Stainless Dump Pipe Set - Nissan Skyline GTR $399 JustJap (or second hand x-force ones for 350?)
  • Bosche 044 pump $275 JustJap
OK now thats what I have got lined up for the enigne side of things - i'm going to be doing a engine out for the first time so it should be good.
If you can think of anything I should add to the list of modify please do. I would like all types of input. My goal of 300kw ATW should be reached with all that gear?
Thanks
Edited by whiteboy01
I dunno if you have them or not already, cam gears, have them adjusted for midrange torque to help get boost on sooner.. ISC/Justjap/GKTech sell a same (ok) pair for $199
Camgears? or should i get some cams?
depends on the budget. cam gears give a nice little gain for the money. plus if you do later get cams they are useful for getting the most out of your new cams too.
Thanks. Might look at cam gears and get cams later on - this is only a mild build so nothing crazy.
Just jap seems like the place to get most of the piping and gaskets but is quite expensive for injecters/dumps.
Still hunting around for brangins.
Thanks
Ok guys
Bad news - one of my turbos has let go for good - the car cant idle at all and is blowing enough back smode to have a disco in it.
I have done a compression test and it returned all but one at 150 the forth one returned 142ish lower then the rest.
Booked in for a leakdown test and I will go from there.
It's a shame that if my enigne has let go, i will be going RB30 bottom end and the turbos will be wasted =(
O well - bring on Wednesday.
Cheers
Ok guys
Cheers
Ok guys
Brought a RB30 BLOCK for 50 bucks YAY going to get it acid dipped and checked out at my local machinest.
Next on the list is new bearings. Problem is i don't know were to start. Is there a kit you can buy with everything included? I don't think forged is worth it for 300kw or is it? I have notice RIPS are selling "new" blocks with stock pistons for 400hp so i think it will be safe.
Will my turbos be suited for the RB30 or should i go bigger?
Anyways i will continue to read the RB30 thread and go from there.
really? They wont be wasted as such?
I dont believe so especially if you going to stick with a freshened up stock bottom end
I personally have a RIPS stock internal long motor with a GT35R - 1.06 rear and to be honest the exhaust housing is kinda overkill for my needs im only looking for ~330 - 350rwkw
You will piss in that with -5's and have fantastic response I would think there would be some 3L's in the dyno thread running -5s search through there the torque curve would be nuts :banana:
How much did the RIPS block set you back? Did it come with everything you need?
Thats what i want - crazy torque curve!
I will have a look now.
I got a stock internal Long motor with one of their custom plenums
Didnt purchase it direct from RIPS it was being sold brand new unused by another forum member so i got it for considerably less than what he payed RIPS
They have pricing on the website: http://www.ripsracing.com/products.html
RIPS do awesome work but there are heaps of guys locally that know how to screw a motor together that I wouldnt hesitate in getting to build another motor for me
Also on the computer Power FC @ around $1k is probably best bang for buck and will definately keep you out of trouble
but if you have a little more to spend check out the Link G4 ECU's I was going to go for a Haltec Platinum until I saw what these could do - I just got one direct from NZ
by the time you buy 2 x Z32 AFM's for around $600 your already ahead :banana:
by the time you buy 2 x Z32 AFM's for around $600 your already ahead :P
Thanks =)
Going with the NISTUNE only becasue i trust andrew at HYPERDRIVE to tune it.
I might look at secound hand RIPS engines - There engines are quite expensive! Must be a brand thing. Meh
z32 AFM are on my short list as well. Just need the money :banana:
Thanks =)
z32 AFM are on my short list as well. Just need the money :cool:
OK guys done some pricing!
  • RB30 Short Block - $50
  • Acid dipped and cleaned - $70
  • ACL rebuild kit to NA standards (pistons, bearings ect) $650
  • Nissan Gasket kit - $350
  • Putting the engine together myself with a mate - $Free ;)
  • Reusing RB26 parts $Free ;)
Thats were i'm at the moment. I was reading over the RIPS pricing and standards and they are only using the standard NA pistons and bearing for 600HP. So it must be good enough for me! (unless someone can tell me no?)
Cheers
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
