  • Replies 212
I havnt got the car yet but getting one within the next couple of weeks should i get this?
How much would it be if i were to buy one seperately?
from experience, buy it now, at least u dont have to wait AGAIN for the kit to arrive in future..
hey guys
does anybody know what those gold cables are in my engine bay?
cheers,
Danny
Danny,
I think I found out - your grounding kit with gold wire is Nissan dealer option...
http://www.japanparts.com/db/partslist.php...=11&volkey=
see pic - very similar to yours
buy it seperately will be USD$165 per kit
Hey Fox, I maybe a goer also! Before I commit, I would like to know if the Auto Trany's are one of the big winner's in this Mod, and how does the grounding improve the shifting time, I've always thought hyd/ic's played the biggest part in auto Transmisson performance, have you any info on this? Regards G.T. [Geoff]
To quote someone I used to work with, was even more relevant because we were in the middle of the Pilbara at the time but "It's better to be looking at it than waiting for it"
Yes, the biggest benefit of this mod is more responsive shifting for automatics while in manual mode and to run ur car smoother.
1. FoxV35 (BLUE)
2. moomoolulu (BLUE)
3. BLISTC (RED)
4. Siglapian (MATTE GREY)
5. MILLOS (BLUE)
6. V35 Matt (RED)
7. Popeye (Blue)
8. Vai350z (Blue)
9. xtc (Blue)
10. Will Power (Blue)
11. rs73 (MATTE GREY)
12. Edwin (MATTE GRAY)
13. Oaksey (BLUE)
14. Dannyws (matte gray)
15. NA_R33 (blue)
16. nissan rules (matte gray)
1. FoxV35 (BLUE)
3. BLISTC (RED)
5. MILLOS (BLUE)
6. V35 Matt (RED)
7. Popeye (Blue)
8. Vai350z (Blue)
9. xtc (Blue)
13. Oaksey (BLUE)
15. NA_R33 (blue)
how many of us from Melbourne? maybe we can ask him to send it to one person then just pick it up from him...
just my suggestion!
Danny,
that is interesting that the grounding kit comes as a Nissan option...
Im curious how it would compare to a customised one.
I'm from Melbourne Edwin....Carlton.
I'm fine with that idea, also fine with paying $5 extra for direct shipping as per the emails.
That of course depends on whether the seller agrees. I don't know because that would not constitute much of a saving for himself if the needs to send 16 small packages rather than one big one.
Less posting address for them, less mistakes/problem(missing, wrong address, damage, didnt post...) IMO
Lets just ship to one of the guys of state, and organize pick up. Less headache for organizer? (i think most ppl are happy with this arrangement?)
Shouldnt have a problem with tax, IMO. Unless we post everything all together..
Melbourne:
1. Dannyw
2. Millos
3. Edwin
4. Siglapian
5. Vai350z
6. RS73
7.
Sydney:
1. Foxv35
2. moomoolulu
3. Blistc
4. V35 Matt
5. Popeye
6.
Perth
1. XTC
2. Will Power
The list isnt complete, i may miss a few out, so update yrself if you dont see your name please?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
