  • Replies 212
I havnt got the car yet but getting one within the next couple of weeks should i get this?
How much would it be if i were to buy one seperately?
from experience, buy it now, at least u dont have to wait AGAIN for the kit to arrive in future..
hey guys
does anybody know what those gold cables are in my engine bay?
cheers,
Danny
Danny,
I think I found out - your grounding kit with gold wire is Nissan dealer option...
http://www.japanparts.com/db/partslist.php...=11&volkey=
see pic - very similar to yours
buy it seperately will be USD$165 per kit
Hey Fox, I maybe a goer also! Before I commit, I would like to know if the Auto Trany's are one of the big winner's in this Mod, and how does the grounding improve the shifting time, I've always thought hyd/ic's played the biggest part in auto Transmisson performance, have you any info on this? Regards G.T. [Geoff]
To quote someone I used to work with, was even more relevant because we were in the middle of the Pilbara at the time but "It's better to be looking at it than waiting for it"
Yes, the biggest benefit of this mod is more responsive shifting for automatics while in manual mode and to run ur car smoother.
1. FoxV35 (BLUE)
2. moomoolulu (BLUE)
3. BLISTC (RED)
4. Siglapian (MATTE GREY)
5. MILLOS (BLUE)
6. V35 Matt (RED)
7. Popeye (Blue)
8. Vai350z (Blue)
9. xtc (Blue)
10. Will Power (Blue)
11. rs73 (MATTE GREY)
12. Edwin (MATTE GRAY)
13. Oaksey (BLUE)
14. Dannyws (matte gray)
15. NA_R33 (blue)
16. nissan rules (matte gray)
1. FoxV35 (BLUE)
3. BLISTC (RED)
5. MILLOS (BLUE)
6. V35 Matt (RED)
7. Popeye (Blue)
8. Vai350z (Blue)
9. xtc (Blue)
13. Oaksey (BLUE)
15. NA_R33 (blue)
how many of us from Melbourne? maybe we can ask him to send it to one person then just pick it up from him...
just my suggestion!
Danny,
that is interesting that the grounding kit comes as a Nissan option...
Im curious how it would compare to a customised one.
I'm from Melbourne Edwin....Carlton.
I'm fine with that idea, also fine with paying $5 extra for direct shipping as per the emails.
That of course depends on whether the seller agrees. I don't know because that would not constitute much of a saving for himself if the needs to send 16 small packages rather than one big one.
Less posting address for them, less mistakes/problem(missing, wrong address, damage, didnt post...) IMO
Lets just ship to one of the guys of state, and organize pick up. Less headache for organizer? (i think most ppl are happy with this arrangement?)
Shouldnt have a problem with tax, IMO. Unless we post everything all together..
Melbourne:
1. Dannyw
2. Millos
3. Edwin
4. Siglapian
5. Vai350z
6. RS73
7.
Sydney:
1. Foxv35
2. moomoolulu
3. Blistc
4. V35 Matt
5. Popeye
6.
Perth
1. XTC
2. Will Power
The list isnt complete, i may miss a few out, so update yrself if you dont see your name please?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
