When spending $20 000 plus on a strong 600hp rb26 it's very important that it gets tuned right the first time. I have been looking around for awhile and heard all the stories but who to believe.
So who is the best to tune a street and track 600hp rb26 running power fc ?
https://www.sau.com.au/forums/topic/273271-who-is-the-best-tuner-in-australia/
  • Replies 42
depends where you are. I would suggest Yavus @ Unigroup or Mark @ Godzilla, if you are in VIC then Racepace
from personal experience & after back to back tuning from 3 other tuners (names disclosed) i vouch for CRD, im in the same position as you - engine rebuilt $$$ & ready for dyno tune over the next week or so.
unigroup is also great but only from what iver heard
hmm depends i have far more respect for tuners in other fields like race bikes (ten times our engine technology), jet, boats and southern 80 boats and especially race aircraft...... put simply if you tune a plane wrong it ends in death.....
its all about what vehicle and for what application..... carb, injection, land, sea, air etc....
Drag tuning (EFI) is by far one of the simplest facets of the tuning game.
Edited by URAS
i miss my race bikes days :P
regarding bike tuning depends on what ecu it is running as most use a 'power commander' which has the same respect & marketshare as the ever famous 'powerfc' :laugh:
bikes rock (so do GTR's)
Mmm it's a bit of a subjective question..
For nissans in Vic +1 for Racepace, have used, I have no issues recommending them or using them again...all good.
Who can take a rainbow
Wrap it is a sigh
Soak it in the sun
and make a strawberry lemon pie?
The candyman?
The candyman
The candyman can
The candyman can cause he mixes it with love and makes the world taste good
^ sooner you grow up the better for the forum.
Your snide comments of late and attempts to draw comments/attacks all the time are getting boring and making you look like and idiot.
Please grow up or i'll stick you on post review - ive asked nicely once already.
Anyhow... Who is the best? Its totally subjective.
Everyone will have thier own view, some people have bad stories of places, good stories of others.
Simply put - you do your own work. Ring around and find the tuner that suits you best.
Although considering you are spending 20k on a motor, surely there is a tuner that is associated/known or even the workshop thats putting the motor together?
If your building yourself i'd be more worried about your parts/assembly than the tune to be honest. And thats not to say you will do a bad job... just that there are many little tweaks to get a RB26 more reliable that only people doing them regularly will know
Cheers
on topic: if your in SE Queensland, then you have a few big name tuners to consider. I use Gavin Wood @ Autotech, there is Matt Spry @ PITS, Mick O'shea @ Signature Performance and Peter @ ProTorque off the top of my head, all who have tuned big HP cars and work on a variety of ECU's.
I think Nismoid said it best, "Anyhow... Who is the best? Its totally subjective.
Everyone will have thier own view, some people have bad stories of places, good stories of others."
I have been around classic Chevys, speedway and hotrods long before I got into late model turbos and can tell you if you ask 50 people who have been to the same big name workshop you will get at least 10 that thought they were ripped off.
Any tuner can have a bad day. Some make an appointment and get caught up with another car with a problem and it can get annoying when you have been waiting so long for this big day.
Then again, I went to a big name tuner a few years ago to have my Unichip installed and tuned. They didn't start till 3.00pm then finished it in 30min. I drove it home and no change what so ever. I took it to Jim at Croydon and he tells me the wiring isn't right so he fixes that then 2hrs on the dyno later I couldn't believe the difference, just amazing.
You would be shocked to know the Unichip installer.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
