Okay bout a week ago I had a 4 hour long phone call with Old mate Duncan and out stupid minds turned to Space frame Cars. After scouring through My105 we found a few interesting ones but nothing that fitted the bill.
So A little R32 GTS-T bare shell happened to fall into my lap last night and its now been decided that it will become a fully space framed R32.
Basicly we're (jay is being roped into the build) going to cut the entire floor pan and chassis out from under the shell and retain the original sills, A pillar, B pillar and part of the C pillar in accordance to the rules.
From whats left we'll build a comprehensive space frame chassis that will incorperate everything that needs to be there and nothing that doesn't
Engine wise we have to retain a max capacity of 6Litres, So a stroked RB33/26 is to be built. We've already got enough calipers and parts to build a car so there is really not much to purchase other than Chassis related rose joints etc etc. The Idea is to mount the block so that the 3rd cylinder is under the windscreen line. From previous cars and talking to a couple of well known suspension experts this is the best we're going to get with an inline 6. Obviously anything that needs to be fabricated to make it work will be done.
The body will be a composite Moulded shell based on an R32 GTR but I think it was 130mm wider each side Duncan and I decided.
There is a heap of discussion going on between several people about the way its going to happen but im open to suggestions from people about the best way to mould a body and so forth. Chassis work is no problem been there done that. Its the stuff we've not done before thats going to be interesting.
Here is the donor, kinda a shame to cut up a pretty straight shell but meh
https://www.sau.com.au/forums/topic/273508-skyline-space-frame/
  • Replies 245
Should be interesting.
Will be cutting the thing up in the next few weeks so will be sure to post up photos of what happens.
I think we've got alot of the bases covered besides actual suspension geometry the chassis is sorted design wise as is the body shell and components.
I've been looking at different designs to model the suspension off. Got a good idea which way were going to go with it.
Duncan your not getting outta this, it was your stupid idea that got put into my stupid head. Plasma cutter I rekon. Angle grinder makes too much noise for my neigbours precious ears.
Jay seen it this morning and his first sentence was What the f**k is that doing here!
Edited by Risking
Yeah rwd, hollinger and a quick change rear diff.
Already have everything running gear wise besides a tail shaft and engine.
We're building it to go play with the 6L chevy sports sedans at the local state rounds.
Edited by Risking
Yeah we have looked at that silvia. Someone should buy that thing its really well priced!
Its not exactly what I wanted and there is no real provision to fit an RB without cutting up the chassis.
Since we've got pretty much everything to build a car this way works out better in the long run.
Its a project more than anything so buying a car almost finished defeated the purpose of what I wanted to do.
When I built the white GTR I bought enough cage material to build 5 or 6 cages so we even have the material for the chassis.
Its an S13 if im not mistaken.
Doesnt really matter though cause not much of the S13 is really left.
The only R32 parts im using will be the door jams, A pillar, B pillar and bit of the C pillar. Roof will remain but thats bout it, No floor or chassis rails
Space framed race cars are basicly a chassis and rollcage with a fiberglass body over the top that resembles the car you want it to look like.
This is a space frame silvia that was mentioned earlier. Once the body shell is fitted it looks kinda like an S13 silvia.
Here is a pretty good ready about sports sedans in general
http://autospeed.com/cms/title_Anatomy-of-...80/article.html
Edited by Risking
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
