hey guys
hooked the multimetre up to the tps just to check all is ok
i got .45v closed which i'm pretty sure is spot in
but when i pulled the throttle cable to WOT i only got about 3.5v
car is an r32 gtst
also collant resistance was about .4 kOhms at nearly opperating temp, is this right?
https://www.sau.com.au/forums/topic/273845-tps-voltages/
  • 11 months later...
Bringing back an old thread but didn't want to start a new one.
I'm getting the same thing, 0.5V when closed and 3.5V on WOT. What's the go with this, is this correct? I'm measuring it with the car on ignition and not actually running if that makes a difference, but electrically I don't see why it would. Comments?
Edited by PM-R33
https://www.sau.com.au/forums/topic/273845-tps-voltages/#findComment-5261624
the resistor on the throttle position sensor had a wider degree of movement, than the throttle they are connected to. Throttles all turn 90 degress, but most variable resistors turn 110 degrees or even a little more, so the full range of voltage can go from 0 or slightly above, to only 3.5 volts. The ecu "learns" what the full range of voltage is for the TPS thru driving. It calibrates itself.
https://www.sau.com.au/forums/topic/273845-tps-voltages/#findComment-5263904
  • 4 weeks later...
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
