As much as I hate penalty systems for hitting other cars (time added, car slowdown etc), I would have thought that's the most effective way of discouraging collisions.
A damage system doesn't necessarily penalise the person at fault (eg tapping someones rear quarter panel while your both travelling at 300km/h ;) ).
On online if you or someone tries to hit someone else at a greater speed, the car about it hit will turn into a ghost and go through the other person so there is no collision. So say your entering a corner from the main straight and you brake late and the other guy is close to you ahead, you will turn into a ghost and go through.
was speaking to my mate at harvey norman yesterday. asked him about the release date. he said that all they have been told is that it will be november. no official date in november yet though. also no word on any of the collectors editions, etc. he said they don't normally get announced until 1 month before release.
ed games said 1st november
standard edition is 99
collectors is unknown but it comes with an R35 GTR model and a book about cars
i don't think it will be 1st of nov. i think it will be later in the month. the US has nov 2 as their date, france (and therefore most of europe you would assume) has nov 24 as the reported date. i would expect us to be similar to europe.
and i am well aware of what is in the collectors edition as i was the first person in this thread to list up what it comes with. you also left out that that it has a keyring and some bonus cars in the game. and as i also said earlier in the thread, it has been reported that there will be an ultimate edition that could be up around $400
of course there will be tyre marks on the road you jagaloons!
just be patient!
don't EXPECT anything... when you "expect" it makes an EX out of PEC and T
in the rally stages at night, the dust which is kicked up behind the car - reflects the light.
if they do THAT detail... there will be skid marks.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
