baaaaaaaaahahahahaha, i laugh so much because i know how you feel had that happen when getting my licences. i thought i was going to suck at the AMG challenge but i actually did quite well. generally silver first attempt (didn't bother trying again). the very first one i did i was just planning on passing it and not caring what i got. do the first run, get to the fast left hander over the crest before the right hand hairpin and finish line (the first section of the track) and i had a massive off, into the wall, across the road into the sand. get back on the road, about 50m from the finish, look at the time, has just ticked over the time for silver. so i had to do that one again knowing that i could easily get silver.
B-spec Lev.25 baby! :banana:
Easy street now- Much less button pressing required
Time to set Bob on getting me my X1 f**ken
easy street you say? i dont think so.. why would there be any less button pressing? and dont tell me your going to be a douche and put a le mans car or something into an endurance race full of stock jap street cars, wheres the fun in that?
the first endurance race only gets ur xp about halfway thru level 25 meaning you either do it again, or re-do the other races over and over and over..
There's not really to much fun in b-spec anyway. The drivers I have suck
I get so frustrated when my driver won't get up the inside into a corner, or struggle to overtake on the straights. I think the b-spec mode was way better in gt4 where you could just set the speed you wanted them to go but I guess there trying to make it a bit more technical in gt5
I tried B-spec the other day... first race and I put the prick in my mod'd R31... big mistake.
every fkn corner exiting crazy power oversteer but i'll give him a little credit... he didn't ever actually lose it, just came dead last :)
lol yeah, i've said it before and i'll say it again, the low-level b spec drivers are mentally retarded.
when we a-spec, we usually late brake into corners taking the inside and forcing the opponent out wide. the b-spec drivers do start making more heroic moves like this and pull way better times at higher levels, my best driver is level 24 atm and he's pretty awesome, although i can still get better times myself.
Edited by jonboy
that's EXACTLY what I'm gunna do mahfugga. or should I say -am- doing; Bob and my Minolta should be just about finished taking the big stick to the competition for the 3rd time on the Grand Valley enduro
and you'll no doubt be pleased to hear I plan on using the most over-qualified car possible for every endurance race between now and nabbing that X1 :D
that's how I roll. oh yeah
my B-spec drivers are still retarded. they are only at around level 8. i had one in my lp560, in the french only race on the madrid track i think (one of the city tracks). by the first corner he was up to 3rd by the first corner. had some alfa and a (i think) lancia or something like that in front of him. was still in 3rd after the second lap. as you said, no taking the inside line, etc. on the straights half the time he was just ramming the rear of the car in front rather than pulling out to go round them. then if he did pull out he would only just have the nose of the car up to about the rear wheel then even though he would be on the inside line for the corner he'd brake early, then floor it quickly then brake again. then he ended up spinning out. he managed to get into the lead eventually, but the front bumper was barely still attached.
for the sports truck one at daytona i had an ford SVT and i had to fully modify it for the moron to be able to win. he was just too slow on the corners that was was last by the end of the first corner even with it semi modified.
can't remember if it has been posted in here or not (and too lazy to go looking), but this video shows how dumb the B spec drivers are. the b-spec driver has spun out and can't get going again
http://www.youtube.com/watch?v=CKNk8jN9vfs
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
