Hey guys.
So I am doing a bit of research in preperation for a big upgrade for my car (pending results of a compression/leak down test :) )
Obviously what ECU you use is important and is a fairly large part of the upgrade expense.
Anyway I know every man and his dog has a Power FC, mainly because they are tried and tested and are known to work well. Which is all well and good. However they are fairly old now, are still quite expensive and are starting to get hard to come by. (Sort of anyway)
I was looking at finding a PFC and chucking on a z32 afm.
However, what are peoples thoughts on the Haltech Platinum Sport 2000?
Suposedly plug and play, comes with a built in map sensor (so no buying a z32)
Supports all sorts of funky things like Anti-lag and launch control (I am fairly sure the PFC doesn't)
Overall it seems to be more advanced then the PFC.
I did a search for Haltech related threads but there seems to be very little info regarding the PS2000.
If the PFC is still the better option, why? Are Haltech's horrible to tune? Do they not handle skylines well or something??
https://www.sau.com.au/forums/topic/275215-haltech-ps2000-thoughts/
The Platinum Sports ECU's replace the Haltech E11 and E8's im pretty sure. haltech has a reputation of being a very good ECU, plenty of people on here run the E11's. Only downside I see is that the PS2000's dont use knock control which is why it may be worthwhile considering a ViPEC or Link if your running a street car, but then on the other hand neither does PFC...
Ok thanks for that. Sounds like the Haltech isn't such a bad option. Not sure if the tuner I plan on going to is familiar with Vipec/Link, I think he more does Power FC and Haltech,
there is your answer, the ECU is really only as good as the tuner and you are more likley to get a better result with ecu's your tuner is familiar with
Totally agree, talk to your tuner and see what they recommend.
Cheers
Johno
Yes, and from what I understand although he has done Many PFC's, he is very experienced in Haltech, which got me looking at them. I was just kind of curious to see if there was any known issues regarding the PS2000 and skylines that others might have come across.
can you run a PS2000 on AFM's? or does it only work on a MAP sensor? I know the R35 and 370z one's use the AFM.
Yep you can still retain your AFM's with the Platinum 2000 and Platinum 2000 Pro. It also has a built in 2 bar MAP sensor.
Cheers,
Johno
I'm running a Platinum 1000 and can't complain, car runs very well and so far it seems very good on fuel, I've only driven it a couple times since its been installed and tuned.
I chose to run a 3 bar map sensor as it was cheaper than a Z32 and also with running the "external" map sensor I didn't have to run a vacuum line inside the cabin to the ecu.
  • 4 weeks later...
Haltech's are bringing out new Ecu's specifically for the R33 + R34's but they will be a few months, i dont know too much beyond that.. but i was talking to hitman about getting a 2000 and he said might be better to wait it out.. which i need to do anyway.. still gotta buy injectors etc.. so just buying all the goodies first, ecu last.
picking an ECU is a pretty important part of modifying your car
selecting the wrong ECU can cost you time, money and lots of frustration
the ECU plays a crucial role in how the car acts, runs, performs and drives
forget the max power rwkw for a moment and think about the important things to you and your car
essentially any ECU you choose will make the same power etc so thats not important
most people when they pick an ECU go - oh sick, no AFM, or sick as, it has anti lag, spark cut, pro launch etc
these are good buzz words but if your car is an average street car that you drive normally and it has a bit of power
whats the point of all these fangdangle features and junk? will they add any value or do they just sound cool?
the most important things for an ECU for a mild street car are - start first shot, cold start, fuel economy, ease of tune, resale value, plug and play and a simple interface. all of these "nice" features are thrown in the bin when you have to wire it in, have only 1 or 2 tuners who can tune it, if it ditches some of the factory sensors in place of aftermarket ones or has annoying operability.
you should understand the key differences between the various forms of technology to understand how the car wil be before/after the change.
do some reading on map sensors and airflow meters to understand which may be better in your situation and why
most people go - oh sick, it uses a map sensor, thats gotta be better - do some reading and double check, you may be surprised
be careful when selecting an ECU thats new on the market or isnt very common
when you are looking at these ecu's factor in how many workshops can tune it and how accessible they are
there is no point having the latest greatest ECU and only 1 workshop in your state can tune
then you are locked into their pricing, their service and their "timeframes" etc.
you will find on this forum a lot of people and probably some tuners, are biased towards the apexi powerfc
you will find this is simply due to their ease of use, access to trillions of tuners, cost, and plug and play
where's dirtgarage to flog the crap out of vipec yo
Nothing wrong at all with the Vipecs.
I know of one car currently being tuned in time for Jamboree with the new Haltech Ps2000, 13B engine with a T51R, so far they are having very positive results.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
