Well technically the engine in your car has 1.998 litres so you fall outside the range unfortunately.
You must also love that piece of shit 2 litre 6 cylinder engine in the Eunos 30X.
Wow :O some one has sand in their vag!
Anyway, recently I have read a lot of info on inline 6's and the more I read about them the more I like them. Especially the way they are balanced with crankshaft design. It seems a bit disappointing how BMW in the new M3 have gone to a 4.0L V8... kind of hor the GTR went to a V6 :(
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4680578
  • Replies 57
Posted Images
i love the sound of skylines (oddly enough i prefer the sound of the rb25 over a 26), and i really like the sound of the ford 'barra' turbo (xr6t motor) as they sound a lot like a rb, but beefier, but there is one breed of engine that gets me harder than chinese algerbra and it isn't a 4, 6 or 8 cylinder.........
lamborghini exhaust note ftmfw!!! either their v10 or v12.
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4680641
"i love the sound of skylines (oddly enough i prefer the sound of the rb25 over a 26)"- Ever since swapping from RB25 Stagea to a GTR I have been thinking a similar thing..
Inline 6 love for me started with an old 4.2 LPG Patrol, "Hmmm, turning right at a round about, 4th gear should do it," and with a set of extractors and a big zorst on it, it sounded sweet.
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4694166
So people do realise the BMW are dropping all in line 6s next model range. Ditto Ford, Merc and Holden already doing so. Nobody is making straight 6s. Does anybody actually make an all alloy straight 6? Didnt think so for pretty obvious reasons. Even the M engines are all cast iron blocks
I can live with the death of the straight 6 if all the replacements are 2.5-4.0L V10s and :) But they wont be so it just sux
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4694436
I can live with the death of the straight 6 if all the replacements are 2.5-4.0L V10s and :yes: But they wont be so it just sux
umm..... holden did it about 20 years ago........
but v6's aren't all bad. remember that the new gtr has one
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4695255
And people say GM are behind, but look at everyone playing catch up on the V engine game :yes:
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4695452
And people say GM are behind, but look at everyone playing catch up on the V engine game :D
GM are behind hence why they are in position they are in, trying to keep their head above water. If you looked at their financial position years ago they were miles ahead of Ford, however Ford had a lot more money tied up in R&D which may have helped...
Back OT, it sucks everyone is going the V mainly due to reasons of packaging especially in performance cars, I think it is a poor compromise. I think BMW dropping the inline especially in their performance models is a real shame!
F**k it lets just all buy a TVR Tuscan S!!!!!
https://www.sau.com.au/forums/topic/275466-inline-6/page/3/#findComment-4695782
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
