  • Replies 40
chicks love r33's PERIOD ! LOL dnt think that car had 10 subwoofers like he said though hehehe
aus delievered R35 GTR was a f*kn animal and less then 1 second difference between that and the 911 GT2 porsche
:P
damn i missed it last night....
don't worry nick, jezza's got your back:
http://www.youtube.com/watch?v=joJmLA4DtD4
Pretty funny stuff. I thought all the girls were going to hold up their little pinky's.
I was in the audience for this top gear episode and got to see the car up close..
Didnt really like the inside of it, very custom but each to there own..
I didnt get to see under the bonnet either which was a shame :)
I was right up the front of the audience for the R35 too and then they wheel the lap board out right in front of me lol so my 5 minutes of fame was shoot down in flames :)
if there is a top secret part on that car it is VERY secret cause I've never found one... had a good look over that car a number of times. not really a fan of all the dr!ft logos all over the interior.... certainly some questionable taste. the car overall is not bad, but I would have thought they could have chosen better. like Blitz said that car has been no where near top secret japan and was built in aus.
im just flicking through the particular issue of Speed, Dec-Jan 03, issue 004 (yes im weird, i keep all magazines that i buy)...
now im not saying anything... and i believe baron more than most..
but in the article... Top Secret is mentioned alot. and the top speed run, and top secrets powerhouse tuning potential. it claims to have hks pistons, rods, rings and cams, and a top secret modified crank... now the most suprising thing, is in one of the pics of the rear... it shows, in plain view... a magnaflow muffler.. now what sort of top japanese tuning company, uses a magnaflow muffler, in the myriad of hks and trust pieces... if it was put on for compliance, than thats just plain ghey and should have been replaced with something a bit more 'trust' like
power is claimed at 440kw.
dont know if its appropriate to ask, but just curious. apologies if its not and mods please feel free to delete, but -
is this the same gold gtr that a few years ago the owner was murdered and it was at his funeral?
if anyone can recall?
Yes he was, Richard Carruthers.....
He was one of my brothers friends and he was sadly murdered in his house while he slept!!
Its a shame cause he was a very very nice guy and my brother and i and a few friends were planning to go to Japan with him just before he got murdered!!
He also had a R34 GTR with a few HKS parts on it, his close friend is selling it for him.
He was a very serious car fanatic not just with imports but V8s also! They had Torana's aswell that made some serious power
RIP RICK!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
