posting for a mate,
after having FMIC, BOV, filter, and GTR fuel pump installed by Fussy's, the car is running like absolute crap.
its making NO power! Boost comes on real quick (11psi) but you feel NO pull, and it breaks down and pops out the exhaust etc etc, and just wont rev cleanly.
Ive considered things like coil packs etc and have done the usual check for leaks, cracked hoses etc etc and found everything looking fine.
just wondering who can recommend a good place in sydney to take it to for prob solving and a good dyno tune. Ive rang UAS but they are fully booked out, and Croydon's tuner is currently away.
or, if anyone thinks they know the prob or any tests i can do, please let me know.
(fussy's also did a service with oil and plugs but i dont think they did much by way of tuning as they have no dyno)
Also, The GTR32 Fuel pump installed is louder than my bosch 044 pump!! is this normal?
thanks for any help!
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/
i dont have anything to check the A:F, could be the prob.
def not the BOV leaking as i checked it (could see the valve closed as its a megasonic Tsmart and its wound in tight, and even put the stockie BOV back on.
why does a bigger pump make it richer? i understand it flows more fuel, but isnt pressure what its all about? it has std press reg.
When i took off my microtech making 200rwkw and put the std ecu back in to make 170'srwkw, still running the o44, it still ran as normal, no richer....?
any ideas on whos good to take it to?
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/#findComment-579043
Just a few things you can check.
What type of filter has been installed and how much oil is on it?
Pull it off and check to see the AFM hasn't been coated in oil.
Then i would look at the fuel pump because it's very likely that it's running rich.
I have a 32gtst with pod, ic, exhaust and boost controller running up to 16psi on the stock fuel pump. Got an AF meter just incase but it sits in the full rich zone all the time when boosting so it isn't underfuelled (and this is the stock fuel system with no mods).
I'd also check your plugs and see if they are really black (and i mean REALLY black, slightly blackened is good), which will indicate very rich running.
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/#findComment-579566
Originally posted by BHDave
I'd also check your plugs and see if they are really black (and i mean REALLY black, slightly blackened is good), which will indicate very rich running. [/b]
Also when checking the plugs make sure they have the correct gap and that the temp range of the plug is suited to ur engine.
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/#findComment-579846
Originally posted by Jay95R33
The GTR pump would help it run rich too.
J
How could the GTR pump affect anything?
Isnt the Fuel Reg there to control that?
I thought having a bigger pump does not mean more fuel is pumped into the motor.
But it could be a buggered fuel reg, and the car is over fueling.
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/#findComment-580534
hmm.. to me though - wouldn't it be that if you have a slightly faulty pump, the fuel pressure isn't constant and thats the whole problem.. therefore while tuning on the old pump you'd try and dump more fuel in there to compensate at certain points (even if it was just appearing to fix the leaning out).. Then once a new pump is in, and everything is back to normal, you're still running the ratios for the old pump, which were actually overcompensating??? As a result its richer than it now needs to be?
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/#findComment-580566
The stock computer will compensate slightly for a lazy pump when running around with a fairly stock car, it's when you start to max out the injector duty cycle that you start to see problems with the stock pump not maintaining fuel pressure and leaning out.
The problem with running a bigger pump is that the stock regulator/injector combination can't flow enough to maintain stock fuel pressure at idle and light throttle with the higher flow of the new pump.
Have you reset the computer? Just disconnect the battery and hold down the brake pedal for a few minutes with the igtition switched to on. Then reconnect and the computer will revert to it's base program and readjust to the new conditions. Simple, but I know it's fixed a few other peoples problems.
https://www.sau.com.au/forums/topic/27674-r32-gtst-problems/#findComment-581175
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
