Anything else you can suggest? thanks.
Originally posted by Duncan
They sure are road legal.  Should be an huge improvement over normal road tyres.  Have you considered other R type tyres though, there are better ones out there.
Well, it depends what you are looking for.
The Azenis are apparently a good middle ground in R tyres, OK wear and price OK.
I've also used Dunlop Formula Rs which are excellent, but about $2000 per set (235 and 265)
Another type I've used are the Bridgestone Re55s which are even better, but are very soft, would probably only last 2-3 track days. About $1500 a set
Other popular choices are Bridgestone Re540s and I think franks has just picked up a set of Toyo r1rs.
tempe tyres quoted
Falken ST-115 255/40/17 260 each fitted and balanced
Originally posted by SIKCAR
are those prices for 17s or 18s?
what's some good tyres, that don't wear out as quick for about a grand or bit more?
for 17s (235s and 265s)
Is St115 the correct designation for the semi slick, as i thought they were the tip top road tyre...or was that the St415. so basically be sure thats the semi slick tyre not their premium road tyre.
Ive had type R on the back with street rubber on the front, and at the track its not all that bad. On fast corners though my car did seem to want to understeer a little more.
I should put a line to separate them..
the ST-115 is road tyres only..all around tyres
the Azenis asymetrical is semi slick..
Originally posted by Mick Trainer
Whats sort of keys to you guys get out of your R-rated tyres?  Include how many track days you go to.
Mick.
lol, depends :(
I don't use em on the road much (just to track and back). I run falken fk451s on the road, which are a great $1000/set road tyre.
Formula R fronts - about 3-4 track days, (8x20min sessions)
Formula R rears - about 6 track days
Re55s fronts- fronts lasted 3 days at Dutton rally, so I think only 2-3 track days....and they are assymetrical so can't swap side to side
Re55s rears - were on for the same 3 days at dutton, about 50% worn.
My car may be a little unusual with much more front wear, it doesn't have much power so it looks after the rears OK.
