my last post was clear as mud, the point i wanted to make is that its like shifting a truck with the low rev limit.
i havent been that gentle with it :) my question is do i raise the boost/rev limit or wait till 1500km?
  • Replies 477
How much head work did you get done by Greg @ proengines...?
I have a 30 built by Greg and just sent a 26 head over for a little upgrade. Will be interested to see how your setup goes.
I will be running a T51 with 1.05 rear and C4 auto.
im running stock valves, 14hrs of porting was done blending bowls, open exhaust ports, spot face for larger lobes, match port manifolds and full service head
if i missed anything im sure greg will correct me
All calm...sorry Shane...buddy cuddle?
Nothing DiRTy about a 30...lol...ive just bought a nice set of Argo's...hehe
Yes Marko...give it some stick!
ok paul, but be gentle :)
Paul, that forklift is a diesel, maybe you should post it in the diesel block thread? :)
At least the Nissan is infront of the Volvo.
Yeah Marko/Greg that would be good, im looking for someone to do headwork for me very soon, my normal guy is tied up for ages. Looking for max flow. I know a mob in S.A. have got some good numbers, but local would be nice
steve, flow figures should only be used as a guide, if u go chasing 'max flow' u'll prolly find the head will be worse than a stocker.
the results u get from a flow bench are only static volumes, i.e flow in cfm is only measured at set lift heights and they dont take into consideration the rapid change of lift variations from an engine running in the real world (valves open/closed thousands of times and varying amounts)
have a look at the thread i posted about a head i had done recently
hey nick - jim wants me to take it to 1500km, he will then raise the rev limit from 5000rpm to probably 8000rpm? he will also raise boost to 13psi & lean out the fuel, as advised.
he then wants me to take it to 5000km then perform the final tune with full boost & dialled cams...jim is being overly cautious which isnt a bad way to operate.
...im not waiting that long, as advised by greg @ proengines, do the 1500km then let it rip - the block was 'tunnel honed' which helps rings bed in.
Add me to the Paul and Rob list. I've posted it up eleventy billion times, run engine for 20 minutes, until it is nice and evenly warmed up to operating termperature and change the oil filter. Then drive to Bathurst, have breakfast with the guys to let the engine cool a bit and then drive back, that's around 450 k's. What I don't see on the list above is the next step which is "check the leak down". That will tell you if the rings are beded in, the bearings were run in by the time you got it out of the driveway. If the leak down test is OK, then drop the mineral oil, change the filter again, fill 'er up with synthetic and off for the final tune. This pussy footing around for thousands of k's achieves nothing.
Cheers
Gary
a. the 1st 300km i ran run-in oil
b. im now running a new filter with mineral oil
c. next change @ 1500km to full synthetic
im doing the bathurst run tomorrow :( with a mate who owns a worked Ford XBGT, nice car rumbles like thunder (harley equivalent on 4 wheels)
rob & paul...am i really that bad with my emails :) u've given me a complex, i feel like a STOONK C*NT
Marko, that was torqe plate honed. As I said, oil change @ 500, one after that and let rip.
I saw a car driving along the shoulder of one of the parkways here doing about 20km/h with RUNNING IN on a big cardboard sign in the back window. sometimes you've got to laugh.
^^ Yep..thats the correct way to break in an engine properly.
All my engines in the past were fired up on the engine dyno...oil temp reached,then start giving it a few pulls under load to 5000rpm..then pull the string and give it everything .
Engines leak down perfectly.
No way would i be pussy footing around for hundreds or thousands of kays.
Start giving it boost & rpm.
Motor initially run with penrite mineral oil ..half a dozen full power pulls made..then oil & filter dumped switched to royal purple 10-40,then back into it with full power runs.
Only way to do it .
And i have seen hundreds of engines dynoed & run this same way..all with the same results.
Edited by ezy_09s
i remember coming across this article a while back when i had my bike - there are a few guys on gixxer.com which swear by this method - it is a good read
told you you'd like the clutch.....
good work Marko
dennis, its drives like a normal clutch, i gave it the wife test and she couldnt believe it as well, after having a triple then twin plate i will never go back. ive been questioning JB clutches and had the opportunity to get 1 two times in the past but i chickened out my mentality was "as if an aust single plate can hold like a jap multi plate"...i should have listened to paul from the onset
it feels like a standard gtr clutch just a bit springier (for lack of a better word) - you would never know its modified.
after looking at it, i think its the way he utilisies the thrust bearing on the clutch fingers as it sits closer to the tip of the fingers on diaphram then what it did on my previous twin plate.
its get more leverage like this & it feels nice with the 4000lbs pressure plate - maybe u should speak to jim berry direct about this, he'll chew both of your ears off :P
definitely do not wait 5000kms to give it the full tune and full boost. the engine will be half worn out by then let alone run in!! lol.
listen to greg. he built the thing. between 1000kms and 5000kms nothing is going to be achieved by running on a rich, conservatively timed, low boost, low rpm tune. except frustrations and boredom!
if you've done 1000kms then it's well and truly ready for the full ponies! :( get the wick turned up and enjoy. :)
how light could it be? The NPC Twin plate we have in the race car is lighter then the single plate in my road car....it shits me, because it shouldnt be like that!
Is that the solid or sprung centre NPC twin plate?
Looking Good Marko!
Where'd you get the silicon hose cooler kit and fuel rail from?
Thanks
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
