  • Replies 477
Congrat on the set up Marko.
It must be one nice fun beast to drive in.
Yes I think your tuner is right :bunny:
You will need the Indy blue 1600cc if you want to change over to E85.
I am going through the process for my 3.0L and T618Z turbo at the moment.
I had around 90% duty cycle with 700cc injectors at 24psi with a power fc D jetro.
With the E85 and 1000cc injectors, the duty cycle was 100% at 23-24psi!
This was with a faulty vipec adaptor board though. One of the transistor on the board kept the EFI relay on and I have injector buzz even when the power was switched off. The injectors were loosely installed on the fuel rail as well, so I don't know how much E85 juice was wasted with these faults.
Dirt is right, the 3.0L sucks a lot of juice :rolleyes:
I should have the car retune in the next 2 weeks with the 1600cc injectors. I can keep you inform if you like.
Dirt is right, the 3.0L sucks a lot of juice :bunny:
yes well ive noticed it drinks a substantial amount of fuel, its not built for economy so i dont care
i'd be most interested to see your results - please keep me informed.
what hp is the t618z rated at?
i went for a drive last night, its actually much harder to push the car on the road as the power band is much wider than my other setup (i.e. starts spooling @ 3000rpm, rb26 started @ 5500rpm) so i find that im changing gears much sooner than my rev limit (i.e. 7000rpm). i need to get used to it.
i gave it a good squirt in 2nd gear & it broke out into a wild wheel spin :rolleyes:
for the 1st time ive rated my car as dangerous as my previous bike (suzuki gsxr1000 worked with 173.5rwhp)...now im waiting for a litre bike to pick on me :bunny:
That's 58.7% more E85 (700 x 90% versus 1000 x 100%). Something is drastically wrong, there is no way any car I have ever seen with E85 uses 58.7% more fuel. I have seen 25% and the occasional 30% when more power(boost) and/or rpm is tuned for. But 58.7% in the same engine at the same boost and rpm is unbelieveable.
Based on the above I'd say about 30%.
Dirt is right, the 3.0L sucks a lot of juice :P
It depends on the comparison, my last 3 litre used less fuel for the same horsepower than the RB26 that it replaced. Mostly because I used a lot lower rpm, keeping in mind torque x rpm / 5250 = horsepower.
Thanks that will be most helpfull
Cheers
Gary
i gave it a good squirt in 2nd gear & it broke out into a wild wheel spin :(
for the 1st time ive rated my car as dangerous as my previous bike (suzuki gsxr1000 worked with 173.5rwhp)...now im waiting for a litre bike to pick on me :D
A big torque GTR is nuts on the street...id roll on the throttle and it would break traction at 6000rpm...that was with a little more than 1/2 throttle. I was unusually quiet after my first real drive around my test track here in Newcastle. Ill admit it did scare me...very used to it now though and want more. :(
hey gary - the scale along the bottom is kph (0-200)
Have I got it right, max torque is around 4,250 rpm and max horsepower is around 6,100 rpm and it makes less than 50 rwkw at 3,000 rpm? Or is my maths totally screwed up?
Cheers
Gary
A big torque GTR is nuts on the street...id roll on the throttle and it would break traction at 6000rpm...that was with a little more than 1/2 throttle. I was unusually quiet after my first real drive around my test track here in Newcastle. Ill admit it did scare me...very used to it now though and want more. :cool:
chasing hp is a never ending story...i did the hill climb on the old rd coming back after the brooklyn bridge and my mate was following me, i applied the throttle in 3rd gear overtaking a fireblade exiting a corner and he told me i left 4 black lines, felt like a tiger hanging on with its paws
Cheers
Gary
your calculations are not right, would be if it was a rgv250
Edited by Marko R1
Yes it would be nice to have rpm/speed on the X-axis.
Isnt' the rpm limit at 8500rpm on that dyno print out?
Marko, Trust doesn't really advertise any power for the T517z or T618z.
It's not nice for the price that they charge for these turbo.
However I always had good results with Trust turbo so I stayed with them.
The only results I've seen around for T618z are from Uras and this chart
Sydneykid, thanks for the calculation. I was thinking the same too. I've made a lot of changes since the tune mentioned, but I will retune the car at the same boost and rpm for comparision. I will keep you guys informed.
it's an awesome result mate, just one thing and this bugs me all the time. and that's people confusing the dynos measurement of tractive effort (expressed in N) as torque expressed in Nm. that is not 930 newton metres of torque and sadly you can't really compare it to manufacturers who quote for example 320kw and 600nm of torque. it's 9000N. it's a measurement of tractive effort, yes, but it's not the same and not directly comparable or easily converted to NM. it's one thing that always pisses me off that dyno's read 'torque' in this way.
it does look to me it's making about 75kw at 3,000 and 150kw at 4,000 but by 5,000 it's making 225rwkw and is well on it's way! 6000 is making 330rkw, 7000 = 375kw and then it's making 400+ from 8,000 onwards. it would be pretty hairy from about 5,500 when the torque is ramping up hard and hitting it's peak at 6,000 or so.
it's a lot of power in a road car and will keep you entertained for a while I reckon. Greg builds great engines and I've recommended him to a number of people over the years all of whom were very happy.
Is anyone else wondering what that curve would look like with equal lift but lower duration cam profiles?
what about smaller cams, turbo's ,capacity, same dyno, same tuner, same fuel and relatively standard home built engine using only pistons, rod bolts and cams from the aftermarket catalogue?
Edited by DiRTgarage
what about smaller cams, turbo's ,capacity, same dyno, same tuner, same fuel and relatively standard home built engine using only pistons and cams from the aftermarket catalogue?
No not your motor's dyno graph Paul, just cam duration change to Marko's one :cool:
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
