  • Replies 477
rob at rips is running an rb26/30 with factory block and crank making over 1350hp in his 7sec car, he is actually trying to break it but he said it just wont, this engine was built about 3yrs ago :laugh: if its good for rips its good for me
paul is right, its a street driven car
a 26 block is better then a rb30 talking about the block here not the crank size but you guys will be seeing alot more rd28 set ups with 3.4 cranks soon enough
What a great idea an RD28 block would be....an extra 40kg over the front axle on the already front heavy GTR, plus the 5 grands worth of block prep needed to make it fit.
As Marko said its a street car and theres nothing wrong with the dirty 30.
We need vids Marko!
We need vids Marko!
lol - i couldnt agree anymore!
re. the vids...it wont be long, i have a new sony handycam hd which i need to put to the test, it has a youtube upload function :angry:
i replotted my 3rd and 4th gear over each other last night and it looks nothing like that...one line is just under the other...ill scan it for you if you like.
clearly both these runs were conducted in the same gear... the dyno operator has just made a mistake and not entered the right gear into the program
you would be ignorant to think otherwise ;)
you would be ignorant to think otherwise :thumbsup:
Mmmmmmmm, not sure about that mate, we've done back to back dyno runs in 4th and 5th gear and got almost identicle power curves, within 3-5whp or so.
Rob
Rob
Remember that we are assuming the power loss (drive train and traction) between the gears are constant with these discussion. Obviously if they read the same at every single vehicle speed, it just means that you lost power in one of the run.
That is completely different to comparing response between a 3rd gear power run with another 4th gear power run.
Or in some case, I've seen people compare 2 different cars.
Why did I get drag into dyno comparison talk in the first place. Dyno is just a tuning tool :whistling:
Edited by 9krpm
the curves will be the same basic shape but when speed is the bottom axis there is no way one of those runs could be in 3rd and one in 4th.... doing the run in different gears moves the curve along the graph. so the lower the gear of course it will make more power at a given km/h. peak power should be the same, but not at the same speed in every gear. otherwise you'd have a gearbox full of the same gears!
BINGO :):);)
glad someone else has a brain !!!
Edited by Cerbera
Apoligies for giving an example with someones name in it...that was maybe a little too much. (mods please edit name out)
Calling my engine a drag engine is like me calling yours one.
Show me an aussie built RB 30 thats so much more outstanding than what ive got. Im building one to see what all the fuss is about and see if it will actually make what ive already got better. I think the big turbo may enjoy a bit more air...so we will see what just changing the bottom end will achieve.
You were off the mark refering to my engine as a drag engine 9K...that was the point...you have no idea what went into it and how it was put together. The focus when building was to make the engine make as much low down grunt (torque) as possible with the GT-RS turbo's. The reason for this is im making zero boost at the startline as i was using a normal Power FC with no anti-lag, two step etc. When the clutch was popped the car had to be right in the meat of its torque curve pulling the car hard off the line. This resulted in the awesome 60' times which was the real secret in getting a car with limited power into the 9's...it was 60'ing faster than Kier's car with less power and more weight (1470kg) and it didn't need an OS Giken 3L to do this. Only Mark Jacobsen has 60'd a GTR on radials faster than what our car has. A high revving RB26 that has a big flat 5000rpm torque curve is what most circuit guys would kill to have.
Thanks
Paul,
What 60' Times were you getting to get into the 9s with that set-up?
I have a quick question about the Garrett turbo range.
Someone said that the GT-RS (GT2871R 52T i.e. -10's) turbos are still too laggy on the a 3 litre. What i was wondering is if anyone has used the smaller of the GT2871R turbos (the 48 trim) on either a 26 or 30.
They are placed in the middle of the GT28RS (-5) and the GT2871R 52T (-10) yet i have not seen anyone using them, it seems when people want a bigger turbo than a -5 they go straight to the -10, when the 48T is also an option.
This is the turbo i'm talking about, obviously it will need a custom compressor housing.
http://www.turbobygarrett.com/turbobygarre...1R_743347_1.htm
Edited by D_Stirls
come to think of it - mark berrys hi octane r32gtr with rb26 was running gcg modified garrett -5s which cracked over 400awkw as shown on the ignition dvd:
im not sure if he is running the same turbine setup on his new rb30 r34gtr:
...maybe somebody like beerbaron would know this as i think he is well versed in the circuit racing scene
Edited by Marko R1
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
