i had iridiums in my 33 when i got it, they were in there for 20,000kms and were stuffed. put in coppers and they were still fine after 10,000kms. so the reason why iridiums aren't any good is because they are a waste of money.
  • Replies 129
Iridiums are also not ment to be gapped as it damages the end of them. Since most are 1.1 they tend to missfire on high boost applications, hence why most of us run a pre .8 gap on coppers.
y is every1 so against T bolt clamps, they hold on hydraulic hoses on mining equipment fine with 1000+psi im sure they can hold 20psi
n id also like the hear why iridium plugs are no good, i was thinking of getting a set coz arn't coppers only good for like 10,000 clicks?
If you think the iridi's will last 100,000 like they claim - forget that idea.
In a stock application, ye probably, but in a modified one with extra boost - unlikely.
Why pay $120 for a set of plugs that can foul as easy as coppers anything can foul them really, eg: your fuel reg dies, there goes $120 in plugs.
And say thats only 15,000km's into the set, all of a sudden the coppers are worth their price because you change them frequently.
Plugs are like an oil filter, in a modified application change them often, this is a family magna your talking about.
whole heartedly agree...
my last set of coppers were pulled out after 20,000 just for good measure and were still running fine at the time. and that's with 300 very abused rwkw...
the set before that lasted just as long
and the set before that were iridi's and were thrown out after 5,000 odd
Then they most likely are platinums, not iridiums. Not many places keep BKR7EIX in a .8 in stock (atleast that's what i find), most keep the BKR7EIX-11.
EDIT: I just checked back a page and you said PFR7B, yep Platinums.
Edited by PM-R33
yes they come in both 0.8mm gap as well as 1.1, but if you get the 1.1 (which is the factory specified gap for rb motors) they recommend not changing the gap down to 0.8 with the iridiums as it can damage them.
awsome they were the answers i was looking for, so looks like im gna get a set of coppers. while we're on the topic of plugs, what part number do i need or what heatrange should i get and what should i gap it too. they're going on a usual sub 200rwkw rb25 running 10-12psi, im also gonna be changing to splitfires the same time as the spark plugs go in.
cheers
power is a simple calculation of
air + fuel + spark + compression = power
whats the tune like?
whats does the AFR look like on max load?
how is the ignition timing tuned?
whats base idle timing ? check it with a timing light?
got it booked in for monday to be seen by another tuner and have this issue diagnosed.
i dont think the turbo is out of puff as ive seen several other rb25's make atleast 270...and im finding it hard to make just up to 245-250rwkw at anything over 14psi.
plus im getting a massive pressure drop without any detonation...so how can it be producing hot air???
Edited by allthewaytotheskyline
found my problem (fingers crossed)
leaking exhaust gas out of a 10mm bolt hole kinda like a little wastegate that constantly open
which would explain why it would hit 18psi then come back down to 15psi
I think its going to go back into the car with a .82 external gate setup now its all out
also i found a crack at the wastegate hole .I dont think that would have been helping my situation either
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
