Hallo guys,
I did 11.2sec with 130 or 134mph(I don't remember exactly) and 1.9sec 60foot!
Unfortunatly the drag strip was very very bad without glue and very old.
With bumps over 1/8mile as you can see in the video.
Theese bumps caused the accident..
In a good drag strip and with rev limit 8500 I am sure that the time will be mid 10!
In other races I did 1.5sec 60foot but in this drag strip was impossible to do a good launch!
I set the tyre pressure at 7.5psi (cold tyres-before burnouts) in my try for a good time :(
This tyre pressure sure was an other reason for the accident.
At the time that I lost the car I push full brakes and the car did drift because the street has dust and was very old.
Glue has only fore the first 1/16 mile
I tried in the race to tune a little the car with the commander...
Rev limit: 8000rpm
AFR wot: 11.7!!
IGN: 19deg at 8.000rpm
Boost: 2.1bar - 31psi (without vaccum hose at wastegate :P :P )
100octane fuel
Very hot summer day!!! 100F 38C
The car is really fast now!!! :);):P
Ofcourse it needs tune but it is really good instead without tune.
Edited by GreeceS13
  • Replies 79
Did the guy in the S2000 hit the wall because of the collision or because he was taking evasive action? Whatever happened that's a nasty hit - both of you walk away?
Isn't the rule on most strips that if you even get a hint of a loose ass end and don't back off you get in a fair bit of trouble?
Obviously not in Greece..
And if it is..then the guy is a wanker!
**edit** i retract that statement. He's a wanker anyway. He could tell his grip wasn't the best..should've acted on it
then again..i don't know how hard it is doing 11sec runs so i should probably not comment
Edited by Black Widow
^^ to me it looked like the Honda was trying to get out of the way.
The little story thing with one of the videos said that....but being that the OP tagged the ass end of it at 130mph...well yeah
Of course they did......thats why the Honda got out of control too....right.
yeah it def wasnt the 7.5psi in the tyres :) or the fact that he kept the boot into it with the car trying to swap ends
Been over pleny worse bumps than that at similar speeds on dirt, (Legally in rallies) and not had any issues like that... and as has already been said, the Honda was not having any troubles, and unless you car is far and away the quickest thing to ever run on that strip the cause of the crash is plain and simple, you ran shit out of talent
Idiots aren't even wearing basic safety gear.
I'm amazed they weren't hurt or even killed.
The 180 definitely tagged the s2000.
Gotta love 3rd world drags. :)
mate i dont know if i want to see a video of you trying to run a 10, running an 11.2 nearly killed you and someone else.
you can just see a guy in the 2nd video at 0:24 with his hands on his headshouting "RE MALAKA!" that comments sums it up beautifully.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
