Added some bits recently...
Couple more pics here...
I don't think this car looks any good at all!
My 2c, GTR.34Z
^^^ Don't mind him! My car has a severe case of JEALOUSY!!!
He can't stand anything that looks as spectacular as this !!! He is being counselled don't you worry!!!
GREAT WORK - SO IMPRESSIVE!!!
Terry
  • 3 weeks later...
  • 1 month later...
holy crap man!!! they are some NICE SHOTS!!!
and you have one HOT GTR!! i am so jealous!
Thanks mate!
Here are a couple of snaps I took this afternoon after a good wash.
Excuse the amateur photo shots. I'm still a beginner.
  • 3 weeks later...
mate the car is more than amazing, i hope you dont mind me using your car as my desktop background; i seem to alternate from bakes's car to yours now
I ordered the nismo skirts and rear pods now so hopefully my car can look almost as good as yours, im even considering ganador mirrors as they just are soooooo nice. You have fantastic taste!!!!!
Thank you, thank you. You're all too kind.
Cheers. I don't mind at all. I'm sure your ride will come along well. :happy: I'm actually using Mine's Side Mirrors.
  • 9 months later...
hay buddy
i luve ur car, our body work is very similar and i have the same wheels. i have the side skirts at home and the rear pods too.
but where did u get the diffuser from that thing is nuts, looks better than my one. and also the interior carbon stuff, where did u get that stuff from
cheers
julz
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
