SOOOOOO NICE!!!! Hopefully if all goes to plan my skyline will end up like this someday. Would love to do it with twins but and maybe look more at the 9sec bracket. hmmmm may have to start looking for that higher paying job and stop with this roster crap so i can get some overtime and start working those 80hr weeks that i use to lol
But hey nice car mate and looking forward to seeing you out at the drags. hope your still going to be there for winters! I'll be there crewing for Ash Hamblin. if i see you i might come and chat to you.
Good luck with the build mate. looks good so far
  • 3 weeks later...
I thought my T88 was big but looking at your setup jesus... This is going to be one serious car, being up in Mackay though where do you take it for test and tuning? I'd imagine you would be running deep into the 8's eventually, surely Willowbank would be the closest strip to handle the regulations placed on this beast.
Cheers Kingy...ok the updates are:
-Was gonna put photos up today but forgot my camera USB Cable (sorry).
-$2500 worth of SS Braided line and fittings rocked up this week. (Thanks VPW)
-Rear Cradle is in with new beefed up urethane bushes and solid spacers are in, along with new Kaaz 2 way Diff, Billet Driveshafts.
-All New Rear Cusco Suspension arms and Tein Super Streets are in.
-Boot fuel system nearly complete (looks shit hot).
-Engine is in for now, plumbing up dry sump and pre-lube pump set up, catch can, turbo etc.
-PWR Cross-flow Radiator and Breather tank set-up with termo fans should be here soon (Thanks to John at Unique Auto)
Everything is coming together pretty quick, looks quite good for a back yard job, long ways to go yet, not goin to make it to this year jamboree (as of brother's tafe bullshit) but dont think the car will ready anyways.
Thats all for now folks, stayed tuned, more pics coming soon, peace out and be good to your mothers!!!
Cheers
Benny
Seems people underestimate how much fittings and braided lines cost when you get a heap of them.
$50 for a fitting sounds ok.....but when you need 15/20 fittings it starts to add up
Well done on getting it this far, should be a monster
Hi Guys
Will be putting pics up later today sometime, yes i know the budget is a bit crazy, but we are doin it once and doin it probably and want to own one of the wildest R32 in Australia. Some people dont realise that Stainless steel braided lines are so expensive, Dash 12 and 16 fittings are killer, when the car is finished it will have about 4k worth of braid on it. Every single hose you can think of is goin to be braided.
Cheers
Benny
P.S if you want to check out our First Project Car R33 GTR it was in Aprils Issue 120 of HPI magazine.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
