Haha yeah i'm serious i got the receipt for it, bloody ridiculous. Cheers for the link NXTIME ill check it out tomorrow, also Marko R1 where did you purchase yours from.
www.purplepig.com.au
industrial suppliers
Man, this is what i want my dream skyline to be like; hand built, fast as... well anything, and an r32 :D
I'm looking forward to seeing this finished man, the closest thing i'm doing to working on a car is finding average audio parts for the incoming pulsar :)
Hope everything goes well bro. It had better do under 10's :( haha
Hi Guys
Finally Figured out how to put pictures up properly so here's a heap more:
PS If it doesn't do a 10 sec pass straight up, ill burn it to the ground hahaha!!!!
FRONT BUMPER GONNA LOOK SOMETHING LIKE THIS:
TBO CARBON FIBRE DOORS 5.9KG EACH
CARBON FIBRE BOOT
CARBON DOORS FITTED TO CAR
BRIDE ZETA III LOW MAX WITH 6 POINT TAKATA HARNESS FOR DRIVER AND 4 POINT FOR PASSENGER
CARBON FIBRE DASH IN CONSTRUCTION
SUPERIOR AUTO CREATIVE CARBON INTERIOR GOODIES
CENTER CONSOLE PAINTED 2 PAC BLACK WITH CARBON TRIMS
WORKS BELL STEERING WHEEL AND QUICK RELEASE SETUP
ROLL CAGE PAINTED
PWR CROSS FLOW RADIATOR 55MM CORE
PWR PLUS THERMO
MASSIVE FUEL SYSTEM
Got the carbon goodies from RHD Japan, yeah the boot could be getting a custom drag wing mounted to it, as we are gonna run the factory panels for street trim (cause of the cops and want sleeper look) and use all the carbon goodies for serious race events.
Hi Guys
CARBON FIBRE BOOT
ROLL CAGE PAINTED
PWR PLUS THERMO
MASSIVE FUEL SYSTEM
Very Nice indeed!!!
Hi Guys Just an Update..
Waiting on turbo to get Adel wiggins Ferral welded on, also had to send the Throttle body back to Hypertune as they will dissasemble it and weld the 4" Wiggins Ferral on for us and reassemble etc. I finished wiring the 5 fuel pumps up today on seperate relays all controlled by there own pilot switchs in the cab.
Hoping to Order the rest of the -4 braid soon to finish off boost lines and other little fiddly jobs.. my dad will be speaking with Mark Jacobson this monday in brissy, hopefully to arange a rough date for when the car will be heading down that way to get run in and tuned.
If anyones looking at ordering Adel Wiggins clamps I have researched everyone under the sun.. ended up dealing with Gas Motorsports, the clamps are rediculously expensive but boy do look shit hot. haha
Hey mate nice build so far. But it looks to me as though you have a lot of the rear of your radiator core blocked off with the aliminium plate might pay to make some new brackets as there isnt much point having such a big core if the airflow cant get thru there because such a large area is blocked off. And just wondering why 5 fuel pumps ?.
Did you guys solid mount the engine to the chassis? The wiggins clamps don't have any flex, so if your motor moves and the pipe work is secured down to the chassis/body- somthing is going to give and it aint gonna be the wiggins clamps.
GL
Justin.
GL
Justin.
Edited by AD4M
Hi Guys just some reply's to ur questions..
first one to you dazmo, yes the back of the radiator is completely covered, this is the new design from PWR used on the Aston Martins Cars.. has a thermo fan and 3 rubber flaps which we havent put in yet.. when the car is iddling the flaps close and draw more air through the radiator.. but when driving along the flaps open up the air is alowed to pass through.
Five fuel pumps, haha yes one is for a lift pump to the SARD 5L surge tank, and four pumps for when the car runs on methanol. Our alternator has been rewound to 120Amps from the standard 90Amps because each pump draws 13Amps and CDI will pack a punch too.
second to Xrated, we have welded our engine mounts solid as a rock.. we didnt use wiggins clamps on the intercooler and stayed with normal silicon hose for flex there if needed.
Hi Guys
Here's an update for you's:
Progress so far, most of the wiring is done, the engine has been put in for the very last time and everything bolted in now and is there for good. The 1.25 inch Adel Wiggins Clamps have turned up for the radiator, so that will be getting fabricated soon. The New brake rotors have also turned up so that will be getting put together as well.
As the pictures will show the interior trim is getting put in (What is left of it) so its starting to look like something!!!!
Cheers
Benny
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
