Hi
I ordered a Cover King "Storm Proof" cover from USA a few days ago. Was $540 AUD including shipping. Suitable for outdoor use and has lock system. The other OEM didnt seem as good quality, wasnt many good reports on the UK forums. I'll let you know how the Cover King one fits once it arrives.
http://www.carcoverworld.com/coverking-carcovers.asp
I tried Nissan today but the AU service/parts people dont seem to be able to help
Nissan parts service here seems to be poor. Here is a link to an OEM one I have seen advertised. I was considering a cheap off the self repco/ebay type but most of the sizes weren't really suitable or oversized/undersized
OEM Car Cover
thanks guys. Dunno if i can bring myself to pay $800 for a car cover :merli:
I see a number of online vendors selling them for about US$300 (genuine)
The problem is finding one who will ship them to australia for a decent shipping price.
my advice, get one from covercraft. they make amazing car covers and you can discuss with them exactly what the cover is for (ie indoor? outdoor? uv protection, dent protection etc). and they fit very nicely.
http://www.covercraft-pacific.com/online/default.asp
thanks for the tips Guys. I did end up buying a genuine one from a US vendor for $298US + $65US shipping. I didnt need a storm proof one, it's indoors only. The reason i needed one: there was a violent car jacking in my suburb last week (involving a gun and shots fired apparently!) and as i live on a busy road near where it happened, i would rather the car be out of sight when my family is otherwise opening and closing the gargage door.
in terms of paint, car covers do more damage than good in an indoor environment - if you want to keep people from seeing what the car is exactly, that's another story. But if you just want to stop dust getting on it in the garage, etc... you're better off with no cover, because it will scratch the car. You're not putting the cover on ONLY after you've washed the car are you...
The No 1 rule of Car Covers.ONLY AFTER WASHING AND DRYING fit the cover.
they do, but even inside a garage to prevent dust, you're better off without it. If it's a security thing, then that's different. Although having a black cover with a gtr logo on it, not very subtle :devil:
True, but it's just a ltitle logo on the front though isnt it? That's not going to be visible (with car parked in forwards). Plus i think anyone that close to the car (to make out that logo) and looking for something to steal is going to work it out regardless. I'm just trying to hide this from the casual driver by.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
