hay fellas
i dont know how to use the off set calculator so bare with me
i wanna buy some wheels for r34 gtt and i have found the following
volk racing gtc silver face
18x9 -1
19 x 10 +19
how will these fit on my car i know they will stick out, but by how much is what i want to know. i dont mind having to roll the guards but i dont want wide body or anything like that
cheers
julz
https://www.sau.com.au/forums/topic/281150-will-these-rims-fit-my-r34-gtt/
FRONT:
Inner Clearance: 22mm more (the inside of the wheel to the strut housing)
Outer clearance: EXTEND an extra 60mm (position of the outside edge of the wheel)
REAR:
Inner Clearance: 11mm less (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 53mm (position of the outside edge of the wheel)
in short, you'd be mad to fit these wheels.
fronts doubt you'll get it to fit unless you run loads of camber and some guard work
rears some stretched tyres and lipped guards dont think you'll need to pull them if you run some camber?
OP, do not attempt to fit these wheels.
i run volk gtc's on my r34gtt
back is 18x9.0 +24
stick out maybe 5mm from the guard.
i forget what my front offset is, but they it flushish, so probably +29 or something?
but yeah dont even bothered trying haha
i looked at the offset guide and dont understand any of it. standard gtt rims are 17x7.5 +35 all round? i got enkie circulars and the fronts are 17x8.5 +35 with alittle dish and rears are 17x8 9.5 +38 with more dish than the front. if im looking to get new rims can i use the same offset or will i need a different on depending if it has less dish. whats a disc clearance type?
most people on this forum don't have the balls to make these wheels fit.
only put these wheels on your car if you're prepared to tuck stretched tyres under flared/rolled guards, lower the car till the rim almost touches the body, are prepared to spend a bit on adjustable camber and don't give a fuck about handling, tyre longevity, or the opinions of "race car drivers", ie most of SAU that doesn't know the difference between a visual style and practicality.
ie... this look:
otherwise, just pussy out now and save yourself the money and buy 8" wide wheels with +40ish offset that the pundits recommend, as nothing is gayer than some hero that claims "omgggg disssshhhh" but doesn't have the rest of the look down pat to make it look good.
my car is already that low now and i have 17x 9 on the rears and 17 x 8 on the front.
i just want to go up to 18s and i want gtc in gold
ill probs keep looking for a less aggressive offset as i need to drive evryday and far lol
why 19x10 in the rear or was that a typo.
rears should be ok with rolling of guard + some decent camber.
fronts will need a bit of work.
i had 18x9 +14 & 18x9.5 +13 with rolled guards and they stuck out,
they would've been flush if i had lowered it more and/or put more camber in both front & rear.
fitment looks good tho but it does require some work.
18x8.5 +35F and 18x9.5+35R sits just about flush with rears sticking out the tiniest little bit .. just to give you an idea. Unless you're prepared to extensively modify your guards incl. repaint them (as the paint WILL crack with the amount of flaring required) don't bother. Those are not GTT offsets.
are prepared to spend a bit on adjustable camber and don't give a f**k about handling, tyre longevity, or the opinions of "race car drivers"
Yeah in other words, if you're trying to impress randoms when your rock up Maccas, go for it. But on the downside you'll have to learn to live with a car that handles like shit, destroys tyres and is a cop magnet.
Edit: This will tell you how much the wheels will stick out ie. how much more/less outer and inner clearance you will have http://www.1010tires.com/WheelOffsetCalculator.asp ...it won't tell you however the effects on your suspension geometry/handling etc
Edited by Delta Force
i run 18 x 8.5 +30 / 18 x 9.5 +30 on a 33 and they didn't require much to fit at all.... the paint didn't crack as the guards only needed a roll not a flare. i also run the car @320mm centre to guard (pretty low)
bombtrack has the same offsets on a gtt and they sit just inside the guards, we rolled them to fit but it was even less work than mine
there is never a guarantee that the paint wont crack, but to fit those offsets you should be right.
the ones the op is talking about are however a different story...
i wasn't referring to paint cracking with such offsets/sizes ..like you said a simple guard roll would do, if that. With 18x8.5+35 and 18x9.5+35 you don't even need to roll the guard most likely. But with the OPs sizes/offsets he'll need to flare not just roll the guards ...extensive flare too ..which will cause the paint to crack.
anyone been to oran park today? I thought there was gonna be some nice pro comp ..but it was just newbs
Edited by Wacky Dee
  • 4 years later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
