Ive read through endless pages of dyno graphs and comparisons, ive even tried a few combos my self. but im after peoples recommendations as to what would be a good, over the counter purchase to put on my RB25.
I want around 270-280 with awesome response, with the potential to go to 300 ish. Turbo will be in a high mount application and more then likely externally gated.
i have previously run a gcg 3071R with .71 avo rear housing in the low mount postition internally gated and made 280 rwkw with cams and gears. wasnt a bad turbo at all. but i still felt it was a bit of a compromise being internally gated as well. boost control was an issue with this set up.
so yeah... post some suggestions people.
Cheers
Simon
find out what troy (roy) uses on his rb20 and run the same setup on your rb25det
from memory its a td06 from a GTR twin kit run in single form on a proper manifold, external gate
its here
http://www.skylinesaustralia.com/forums/Rb...o-t103095.html#
td06 20g-8cm2 rear housing
with a proper setup
yeah i'd love a TD06 20g, one of my mate has one on his 25 and makes 317 rwkw on 17 psi. awesome response too. however at 4K for the kit its a little out of reach.
after a garret option which would be cheaper yet still effective
You could either wring the neck of a GT3071 (with a 0.82 rear housing) or GT3076 or perhaps something in between like discopotato 03 just ordered ie 52 trim 76mm.
If you have a split manifold you could order a divided housing from ATP which might improve response slightly and would suit any of these options.
For about 280rwkws with fast response you can try a 52T 76mm comp on a GT30 Turbine in BB assemble using .63 rear housing. Or .58 rear housing which would definitely increase response shaving off about 20KWs top end power. You can also replace the standard .50 To4E compressor with a .60 T04B comp. Which can also increase turbo response.
have thought about tuning for E85 but availabilty issues is a concern for me as sometimes its not even for sale in SA. that and the fact for 300 rwkw i'd need 740cc injectors or bigger!
limpus: the 3037 pro s would be my ideal choice for a turbo i reckon. how much you asking?
I was thinking about this last night, 4k for the td-06 kit seems cheap when you consider what it comes with compared to a custom garrett setup.
this is a rough guide, for what I would do with a garrett setup, obvioulsy cheaper if you buy a china minifold.
decent manifold - $1200
turbo - $2000
wastegate - $500
oil and water lines - $300?
Custom Dump - $250-300 in mild steel
intake pipe- anywhere from $10 to 200
Mind you, if you can get a td-06 kit for 4k please let me know where lol
yeah thats the thing tho, exhaust manifold, dump, intake and oil and water lines i do not need to factor into cost as i'll be doing them all myself. So just need turbo and gate really.
that RX6 kit looks insane! lol
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
