Possible Show n Shine Advertising
84 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 45
isn't 2dayfm 104.1 and not 102.5...? just saying....
Peter you may well be right. I stuffed around for like an hour working out how to get this Pole stuff sorted. Yelling at the bloody puter and monitor actually didn't help either.
To the old farts out there in SAU land,,,I didn't add the talk-backs/AM stations only through frustration and the fact I thought I would be the only one.
Neil.
