  • 3 weeks later...
  • Replies 214
Posted Images
  • 1 month later...
Well it has been way way too long between posts but i have got a little more progress.
The new sump and pick up is modified and fitted, the new balancer is fitted and the fitting is in the back of the head and i have made and fitted the head to sump breather line. All that is left to do is tap out the rear of the coolant rail on the drivers side to take a 1/4 BSPT fitting so i can change the hose fitting to a dash 6 AN one, then is it ready to fit.
The engine bay has had a little clean up and all three harnesses are fitted, the fuse box has been re fitted and also the power steer lines and bottle. So there is not much more to do then the engine can be re fitted.
So fingers crossed next weekend all the engine and drive train will be back in the car.
I have laid out the last two remaining harnesses tried to part out the bits that i will remove, I want to remove all the wires for the Hicas including the control module and the sensor in the steering wheel. I have also purchased a Stack dash so the majority of its wires will be removed also. Does anyone know if i will get heavy steering if i remove the whole system? I have heard that this happens if you remove the module on its own. If so can i put a resistor inline to trick the car into thinking that the Hicas control module is still active?
Cheers,
Ryan
Cheers,
Ryan
Sweet thanks Duncan i am just going to pull the whole system out and see what happens.
Also my new Stack Dash showed up today woohoo.
I've run a few times on the track without the powersteering pump connected.
It's heavy, not too heavy. Quite nice for track work, until you get into a position where you might need to be flicking left to right trying to catch it... :blink:
Moving around pits though... That's a bastard of a job... :P
I put the belt back on for this reason and texikhana reasons.
excellent choice, I would definately go a logging dash if I was starting over again.
it might seem more expensive at first but it will be so much cheaper, more reliable and more useable over the years
Well a small up date the engine and gearbox are back in with the new clutch and one of JP's clutch lines all on new nismo mounts.
I had the engine in and out three fing times till i got the sump to clear the LH mount and the fitting on the back of the head to clear the fire wall, but it is all good now. Most of the engine is wired up just need to sort out he exh side and re fit the intake piping ect.
I also powered up the dash the other day, so so cool.
Not long now. :unsure:
Another small update, the engine is all wired up and oil lines, boost, fuel, w/gate is all plumbed up.
I hand to modify the oil supply hose to the steer rack as it fouled on the sump. It is all good now with new brackets, all i need to do now is make a new oil return hose as the std one has no chance of fitting. I think i am going to run a cheap oil cooler on the return side any ways so it wont be too big a deal.
Also fitted some new bushes to the front of the diff and fitted the tail shaft.
It is getting there slowly.
Nar Noddy, i was thinking about it but i would have been such a pain at this stage cause i would have had to run no booster and change the master cyls, pedals etc. But i did get the dash bar made out of 44 mm tube so i can hang a pedal box off it later and run fwd supports at a later stage.
I have been meaning to Pm you about you car for a while now but have never got around to it, so expect a little PM soon bud.
Thanks for the kind words.
Ryan
We got it to fit and still work in mine.
Starts off the leg in here
And pop'sut here with a plate on the tower
Hope to come down some time in the near future for a track day at Wakefield. You guys will have to let me know when some thing is on.
Edited by Noddy
Nice work Noddy, Next time my engine comes out i will attack the engine bay more i think but yours looks nice and access able. There is a SAU day a Wakie coming up soon check out the NSW section for more info closer to the date but i will let you know either way.
Thanks Michael i hope to have it running in 3-4 weeks, i am sick of looking at it not going.
Small update,
I ordered a new Radiator off the SAU group buy Group buy link it should show up next week woohoo. I also ordered some new genuine nissan radiator hoses and a Greddy coolant temp adapter do dar. So i might finish off the engine next weekend, all i need now for the engine bay is a cheap oil cooler for the power steering.
I also ordered a set of the Adj lower control arms for the front so that should finish off the handling side for now also.
I made a new steering wheel boss as the HKB one didn't suit me, so if any one wants a new genuine HKB boss for a Hicas, airbag R33 GTST i have one that i am willing to part with.
So fingers crossed i finish welding the drivers seat in and paint the inside next weekend.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
