  • 3 weeks later...
  • Replies 214
Posted Images
  • 1 month later...
Well it has been way way too long between posts but i have got a little more progress.
The new sump and pick up is modified and fitted, the new balancer is fitted and the fitting is in the back of the head and i have made and fitted the head to sump breather line. All that is left to do is tap out the rear of the coolant rail on the drivers side to take a 1/4 BSPT fitting so i can change the hose fitting to a dash 6 AN one, then is it ready to fit.
The engine bay has had a little clean up and all three harnesses are fitted, the fuse box has been re fitted and also the power steer lines and bottle. So there is not much more to do then the engine can be re fitted.
So fingers crossed next weekend all the engine and drive train will be back in the car.
I have laid out the last two remaining harnesses tried to part out the bits that i will remove, I want to remove all the wires for the Hicas including the control module and the sensor in the steering wheel. I have also purchased a Stack dash so the majority of its wires will be removed also. Does anyone know if i will get heavy steering if i remove the whole system? I have heard that this happens if you remove the module on its own. If so can i put a resistor inline to trick the car into thinking that the Hicas control module is still active?
Cheers,
Ryan
Cheers,
Ryan
Sweet thanks Duncan i am just going to pull the whole system out and see what happens.
Also my new Stack Dash showed up today woohoo.
I've run a few times on the track without the powersteering pump connected.
It's heavy, not too heavy. Quite nice for track work, until you get into a position where you might need to be flicking left to right trying to catch it... :blink:
Moving around pits though... That's a bastard of a job... :P
I put the belt back on for this reason and texikhana reasons.
excellent choice, I would definately go a logging dash if I was starting over again.
it might seem more expensive at first but it will be so much cheaper, more reliable and more useable over the years
Well a small up date the engine and gearbox are back in with the new clutch and one of JP's clutch lines all on new nismo mounts.
I had the engine in and out three fing times till i got the sump to clear the LH mount and the fitting on the back of the head to clear the fire wall, but it is all good now. Most of the engine is wired up just need to sort out he exh side and re fit the intake piping ect.
I also powered up the dash the other day, so so cool.
Not long now. :unsure:
Another small update, the engine is all wired up and oil lines, boost, fuel, w/gate is all plumbed up.
I hand to modify the oil supply hose to the steer rack as it fouled on the sump. It is all good now with new brackets, all i need to do now is make a new oil return hose as the std one has no chance of fitting. I think i am going to run a cheap oil cooler on the return side any ways so it wont be too big a deal.
Also fitted some new bushes to the front of the diff and fitted the tail shaft.
It is getting there slowly.
Nar Noddy, i was thinking about it but i would have been such a pain at this stage cause i would have had to run no booster and change the master cyls, pedals etc. But i did get the dash bar made out of 44 mm tube so i can hang a pedal box off it later and run fwd supports at a later stage.
I have been meaning to Pm you about you car for a while now but have never got around to it, so expect a little PM soon bud.
Thanks for the kind words.
Ryan
We got it to fit and still work in mine.
Starts off the leg in here
And pop'sut here with a plate on the tower
Hope to come down some time in the near future for a track day at Wakefield. You guys will have to let me know when some thing is on.
Edited by Noddy
Nice work Noddy, Next time my engine comes out i will attack the engine bay more i think but yours looks nice and access able. There is a SAU day a Wakie coming up soon check out the NSW section for more info closer to the date but i will let you know either way.
Thanks Michael i hope to have it running in 3-4 weeks, i am sick of looking at it not going.
Small update,
I ordered a new Radiator off the SAU group buy Group buy link it should show up next week woohoo. I also ordered some new genuine nissan radiator hoses and a Greddy coolant temp adapter do dar. So i might finish off the engine next weekend, all i need now for the engine bay is a cheap oil cooler for the power steering.
I also ordered a set of the Adj lower control arms for the front so that should finish off the handling side for now also.
I made a new steering wheel boss as the HKB one didn't suit me, so if any one wants a new genuine HKB boss for a Hicas, airbag R33 GTST i have one that i am willing to part with.
So fingers crossed i finish welding the drivers seat in and paint the inside next weekend.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
