  • Replies 214
Posted Images
All this talk about Morgan Park is depressing me.
Ryan,,,questions on what fuel system are you running if I may be so rude.
Would I be correct in assuming you are using the factory pump as a lift pump and an 040 as the supply pump. Also what size is that surge tank?.
Cheers
Neil.
Come on Neil and Ryan, even I'm going to Morgan park!
Annual leave approved today... :banana:
Well if one of you guys would be so kind as to ring my boss and tell him he can't have hols then I will be there.
Good luck I couldn't even get him to start them on the tuesday.
shit happens
Neil.
quit like I did..hahahahha
Do what he said...
Oh and it looks like I go to Morgan park one weekend ( I should tell my missus about this hey?) then I go to Thailand the Sunday after, then I go to the ACT the day after I get back from Thailand... Awesome two weeks!!!
  • 1 month later...
Well not much doing on the car but went and purchased some race gear i got some boots and a suit all from Monaco Performance Newcastle, i decided on the GTRacegear range due to its great price and exceptional quality. Below are the links to the pages feel free to PM me if you want any info on them. Bring on the 2011 season so pumped.
Suits
shoes
Monaco Performance
Cheers,
Ryan
lol I thought Ryan was the blonde.
too late for you mate, and looks like they are OK anyway....but be aware the CAMS rules for boots are changing next year (actually they changed 2 years ago but there was an amnesty). You now need to the FIA standard (as yours seem to), not just the SFA or whatever the other standard is called
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
