Like I said I'm looking for something thats going to cover me for the max power of the 2860-5's, will they do the job? I just don't want them to anywhere close to maxing out. As asked before what is everyone with sard 700's using? the single hole version???
Nothing wrong with the single hole Sard (Denso) injectors as their spray pattern is really good. I use 700cc ones in my R33 GTR equipped with HKS GT-SS turbos. It makes 330kw at 1.3 bar boost, injectors are at around 65 - 70% duty cycle.
My R32 makes 560kw at wheels with the 1000cc single hole injectors at around 70% duty also. I was running 660cc injectors and made 450kw at wheels on 99%. So 600 - 700cc will definitely be fine for you.
I'm selling the 660cc ones at the moment for a good price and will fit your application well - no modifications.
z32 afms are not better then nismo ones, nismo ones basically have z32 internal, in a standard diameter pipe,
advantages with nismos , direct bolt on everything fits,
disadvantages with z32, needs new plugs and different piping, but be able to stretch exiting piping to fit
id rather get nismo afm as the will flow bout the same
80mm is def less restriction than 65mm.
They aren't just Z32 internals in a smaller housing because if that was the case, it'd max out way too early because the air has to travel faster through the smaller diameter. I reckon a Z32 sensor and circuit in a RB26 AFM housing would max out at about 180rwkw each.
Nismo's are def fine and if he said he had a standard airbox, that'd def be the go but because he has pods, it's cheaper and slightly less restriction than nismos and u get a set of brand new filters with the money saved.
Yeh that's how much until they max out. That PROVES that nismo have different internals to Z32 because Z32 internals in an RB26 housing would max out far less. I didn't say nismo afm's max out at 180rwkw each, i said if z32 internals were put in an RB26 housing, it'd max out at about 180. Read what i wrote again.
Both Nismo and Z32 AFM's can read very similar max flow but the nismos are more of a restriction as they are smaller. It's only marginal i know but if it's cheaper then every little it less restriction helps.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
